Low Mount Alternator Bracket?
Old Jan 23, 2008 | 01:25 PM
LT1Z/28's Avatar
Default Low Mount Alternator Bracket?
Were can i get one these at?
Old Jan 23, 2008 | 01:28 PM
LS1 SPEED's Avatar
We can get you either a MadMan or SJM bracket.
email me if interested
Old Jan 23, 2008 | 01:53 PM
Razor_Blade's Avatar
I made my own for under forty bucks. It took me a little time to get it right, but it turned out pretty nice.
Old Jan 23, 2008 | 05:28 PM
BOLO's Avatar
I have the MADMAN bracket. Nice and easy to set up. Makes changing plugs easier also. You can get one @ Speed Inc.
Old Jan 23, 2008 | 05:39 PM
Revelation Z28's Avatar
i want one thatll mount to where the AIR pump used to be.
Old Jan 23, 2008 | 05:45 PM
SiDeWaYZz28's Avatar
I want to delete my a/c.So does the bottom mount conversiom delete th a/c too?
Old Jan 23, 2008 | 06:27 PM
Yes, it deletes the AC and PS. There are brackets out there that move the PS to the driver side if you want to keep it. There was thread a while back with some good pics.
Old Jan 23, 2008 | 06:35 PM
LS1 SPEED's Avatar
The Mad Man or SJM leave you with an alternator and crank pulley only. The bracket is slotted to adjust for belt tension.
no A/C
no PS
no cast mounting bracket
basically a race setup, but really cleans up the engine bay
Old Jan 23, 2008 | 06:58 PM
Taubr Unit's Avatar
I made my own out of a gen1 alt. bracket i fabbed up to make work. I rev my motor to 7k and never slip or throw a belt......
P.S. All my little rust spots are all gone now!! lol
Old Jan 24, 2008 | 08:47 PM
Ken95Z28's Avatar
I used the same bracket that holds the A/C, Alternator and P/S pump and cut it down. Then made two brackets to hold the Alternator in place.
Old Jan 24, 2008 | 10:57 PM
tylert14's Avatar
^^^ That one looks pretty nice. So does your's Taubr.
Old Jan 25, 2008 | 03:19 AM
LT1Z/28's Avatar
preciate the info guys
Old Jan 25, 2008 | 03:20 AM
LT1Z/28's Avatar
oh and taubr, i talked to you about deleting the powersteering back some time ago, do you have a pic on how you did your lines?
Old Jan 25, 2008 | 05:49 PM
1mean96ss's Avatar
Do you have to take the PS off completely or can i just buy the bracket and bolt the alternator in the place of the ac compressor.
Old Jan 25, 2008 | 06:05 PM
Taubr Unit's Avatar
no i dont have any pics. The 2 lines that unbolt from the power steering box..... cut the ends off thoes 2 and loop them.
Old Jan 31, 2008 | 02:37 AM
LT1Z/28's Avatar
alright, preciate it man!
