What year LT1 is the best?
Old Jan 31, 2008 | 12:35 PM
  #61
LT1MAN's Avatar
i wouldn't have anything but obd1 single cat cars personally, plus, on 94's (which mine is) in NC there is no emission testing, which means you can have a 383 with true duals and gutted or no cats and just spray exhaust fumes into the air without anybody bothering you about it come inspection time.
Old Jan 31, 2008 | 12:37 PM
  #62
Steve in Seattle's Avatar
93 - PITA to burn chips (unlike the 94-97's reflashable PCM)
95 - OBDI with OBDII style connector... can be a PITA until to get the right cable for it.
96 - OBD-II.... more sensors and information for tuning and trouble-shooting, but you'll need a good tuner if you wanta ditch the EGR (which really you DON'T need to do... unless you NEED the room)
97- heads flow ~5cfm more (~10hp), synthetic rear main seal, and a few other improvements. Nothing worth chasing down if you plan on overhauling the engine and porting the heads.
I have a 396ci '97 LT1 and I'd probably go with a '94 if I was pulling the drivetrain for a transplant... OBDI is just simpler to work with (UNLESS you have an automatic trans and a big stall... then you NEED OBDII).
Old Jan 31, 2008 | 12:39 PM
  #63
Originally Posted by Abdullah
btw, i noticed once when i wanted to caliprate the PCM of a 95 camaro that it has the OBD2 ALDL port but it still has OBD1 PCM. i think maybe this car was produced in the late of 1995.
nope... that's normal for all 1995 LT1's (and many other 1995 GM vehicles)
Old Jan 31, 2008 | 12:43 PM
  #64
Originally Posted by FireBird_Fr3ak
Thats my vote, since its not going to be N/A you could use those 4bm's.
several impala for 4-bolt mains as well. Only problem is you need to pull the oil pan to find out for sure which one does.
Just don't pay more than $200 more for the vette engine over the f-body... you can convert a 2-bolt block over for less than that during a rebuild. BTW, several LT1 2-bolt blocks have lasted over 600hp... I wouldn't be so eager to go 4-bolt if this was a simple drivetrain swap or even light rebuild. No mild LT1 needs more than 2 bolts per main.
Old Jan 31, 2008 | 12:47 PM
  #65
Originally Posted by Racin96ss
Sorry, but I didn't read the whoel thread but get an LS1 becuase you can get one of them cheap too...plus there is more support in the aftermarket with them
Modding an LS1 is more costly than a LT1/SBC. There is NOT more support for the LS1 than the SBC...
LT1 has several advantages over the LS1 (like reverseflow cooling, cheaper replacement parts, SBC compatibility, stronger T56 desgin, and easier/cheaper tuning software... damn LS1's need programs for every year and platform variation).
I'll stick with a 500hp LT1 thank you very much.
Old Jan 31, 2008 | 01:42 PM
  #66
lt1 hawk's Avatar
I would just say 95 six speed, because that is what I see the most of all muscled out. I'd say 90% of the beefed up 93-97 LT1s are all 95s. Not sure exactly what the difference was in that year, or maybe they just made more of them that year, but that is mostly what I have seen.
Old Jan 31, 2008 | 02:00 PM
  #67
I'd say your anedotal evidence is wrong. Some of the fastest LT1's ever made were a) automatic, and b) from various years... '96 and '97 being the two fastest I know of (1000+hp).
Old Jan 31, 2008 | 03:24 PM
  #68
lt1 hawk's Avatar
I wasn't talking the most power, I was just talking about what the most common 450HP or higher ones you usually see.... they seem to be mostly 95s.
Old Jan 31, 2008 | 03:30 PM
  #69
Next level's Avatar
ok everyone is saying that the 95 LT-1 is easy to tune, can someone help me tune my car then. cuz im having a hell of a time. PCM4less didnt work, Ian didnt work in dekalb im ready to just throw this thing on a dnyo and do it that way but i know there is ways to do it by just driving around and what not with a turner any easy suggestion ?
Old Jan 31, 2008 | 09:02 PM
  #70
BOLO's Avatar
Where did you get your info on the '97 heads flowing better(10hp)? I thought the increase in hp from 275 to 285 were from the better flowing dual cats OBd2 system. Maybe I was misinformed.
Old Feb 1, 2008 | 06:25 AM
  #71
METALBEAST's Avatar
They do flow a little better, but it has nothing to do with that pseudo rating anyway.
Old Feb 1, 2008 | 06:35 AM
  #72
qwk93ta's Avatar
I thought the 10 HP came from a redesign of the exhaust too.
Old Feb 1, 2008 | 06:46 AM
  #73
LT1MAN's Avatar
they're actually 6 bolt mains
Old Feb 1, 2008 | 07:31 AM
  #74
Formula350's Avatar
Love how everyone posted how their year is the best, because they own that year. Way to be totally unhelpful.
Old Feb 1, 2008 | 08:02 AM
  #75
Abdullah's Avatar
it is known that is best f-body (camaro and firebird) for modding are the 94 and 95.
Old Feb 1, 2008 | 12:05 PM
  #76
lt1 hawk's Avatar
while I think there must be a reason why most of them that are pretty impressive are 95s (did they make more of them?), I think any of them can be impressive. I would rather go with the Trans Am though, because from what I hear they are a little lighter. is there any truth to that?
Old Feb 1, 2008 | 01:13 PM
  #77
riodealz28's Avatar
i would say 97
Old Feb 1, 2008 | 05:02 PM
  #78
camaro-94-z28's Avatar
i would say turn this into a poll and see the majority. me personally 94 buts thats b/c im biased and only worked on 94's and 95's
Old Feb 1, 2008 | 06:22 PM
  #79
3pnt4maro's Avatar
1995 for the win!!!
