New LT1 intake update
(PICK ME!!!)You KNOW you need someone with displacement and heads that can see benefits from an intake like this... stock or slightly ported applications won't figure the cost is worth 10hp in gains. I'm also not convinced any mild to moderate turbo/blower guys need this either...
NA/nitrous guys would LOVE a better flowing intake though... especially if it had a nice boss for a anti-backfire valve, and the rear distributor hole pre-drilled and capped off (for easy distributor conversion
).Whatever the form... please double the plenum size.
I totally agree.....that is the reason I went with the single plane, as it is currently the only alternative to a sheet metal intake.
I had maxed out my old combo (ported LT1 castings and ported Lt1 intake)...My new combo needed a better flowing intake to get the best results.
https://ls1tech.com/forums/showthrea...918&highlight=
I've learned not to get my hopes up over claims like these. I'll believe something when there are pics posted. I mean....design the thing, build it, take pics, THEN post about it. Talk is cheap, as they say.
