My project toward the ltx shootout...
Old Jan 29, 2008 | 12:34 AM
skinnies's Avatar
Default My project toward the ltx shootout...
I'm switching to a header kit from RealQuick, log kit is gone. This should allow me to make as much power as I need.
When I pulled out the motor I noticed some rust on the spark plug, upon tearing it apart, we found the block cracked. At least this explains my issues I had with it heating up some on the highway.
Started tearing into the engine bay first, and destroyed the garage. :p Some of you may remember before that I did a full wire tuck and filled in the holes, we are going over it again and covering up even more this time. Here is a before pics...
Making room for the new Griffin radiator...
First test fitting...
block off plate test fitting...
Then...into the dash...
Rerouting the harness to the top...
Still a work in progress, new block gets dropped off this week at the machine shop, and putting my old internals back in it(stock crank, eagle h beam rods, and wiseco pistons) along with doing another splayed main setup.
Picked up a set of ported heads from none other than Mr. Lloyd Elliot and also a small cam. I'll be keeping the stock wheels and switching to a mt drag radial. 9's at the ltx shootout on the 16's or bust.
Old Jan 29, 2008 | 12:39 AM
nesqwick_05's Avatar
dude some1 took your seats... lol good luck actually, looks really good. any other things going on other then this? turbo upgrade maybe?
not saying your turbo wont cut it, but its always nice to share some info...
Old Jan 29, 2008 | 12:44 AM
skinnies's Avatar
Other than whats mentioned, it'll be on the same turbo(T76), same coan stall, built th400(not a completely stock slipping one like I had on my 10 second passes), hopefully an 8.8 rear end(time will tell on that one, if not I'll be leaving soft, 1.5x 60ft range). I'm also switching to a 2 bar map tune(I tune it all myself) and am building a custom boost controller setup to allow 4 different boost settings on the fly.
Old Jan 29, 2008 | 12:51 AM
94'BLKBRD's Avatar
so ur lt1 is a 355? how much hp do think ur going to make now that you switched to a header setup?
Old Jan 29, 2008 | 04:17 AM
skinnies's Avatar
From above...
Yes a 355, hopefully in the 700rwhp range through my th400/stall.
Old Jan 29, 2008 | 08:28 AM
RealQuick's Avatar
Nice Justin! You will crush 700rwhp (even with the drivetrain loss) .... but lets shoot for ~145-150mph traps as our benchmark.
Old Jan 29, 2008 | 08:48 AM
qwk93ta's Avatar
That's really cool....Is your car in your basement? I see a water heater in one picture.
Old Jan 29, 2008 | 09:37 AM
skinnies's Avatar
My garage is also the basement.
Old Jan 29, 2008 | 03:15 PM
RealQuick's Avatar
Show some better pics of the final radiator mod.
Old Jan 29, 2008 | 03:35 PM
infinitebird's Avatar
Haha, when I first saw that one pic it looked like you were holding up the front end of the car with just the trash can.
Old Jan 29, 2008 | 05:14 PM
chavez885's Avatar
hahaha
Good stuff and cool pics, seeing so many wires makes me cringe.
Old Jan 29, 2008 | 06:21 PM
Taubr Unit's Avatar
hahahaha, didnt notice that.
Old Jan 29, 2008 | 06:34 PM
94'BLKBRD's Avatar
how much does the car weigh?
Old Jan 29, 2008 | 06:43 PM
bricez28's Avatar
man i wish i was going to the shootout...even if i t was just to run 13's....
Old Jan 29, 2008 | 06:45 PM
jakesz28's Avatar
Thats pics of the third car I seen with a stripped int. this year.
Keep us up to date.
Old Jan 29, 2008 | 08:19 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Looks good to me. That wiring looks like a nightmare though.
Old Jan 29, 2008 | 11:09 PM
skinnies's Avatar
Before I took the car apart it weighed 3500lbs exactly, I did remove maybe 15lbs of small stuff, but I'll be puttin in the back seats this time so that'll offset it. It'll be over 3500lbs at the shootout. The car is quite the pig so I'll have to make up for it with pure power.
Keep us up to date.
And it's all going back in. The car will look stock from the outside and the interior will look completely stock with just the two guages in the vents. It should also be a fairly quiet car, I'm sure it won't look or sound like the other 9 second cars I'll be next to.
I used to hate wiring, now it doesn't bother me anymore. I completely redid my engine harness also. Here is some mid way points of doing that, 41 non needed wires removed.
skinnies's Avatar
I will after we respray the engine bay.
Old Jan 30, 2008 | 08:45 AM
tylert14's Avatar
We need to line up at the shootout! You'll probably beat me but are builds are pretty similar in ways man. You're cars looking good though. I see I'm not the only one that hangs there harness from the roof to lol!
Are you getting a roll bar or cage or anything? I got my 6 point most of the way in, there's some pics in my thread.
Old Jan 30, 2008 | 07:37 PM
skinnies's Avatar
Still undecided on what cage setup to do.
