94 or 95 LT1 into a 97
Hope this helps and let me know if there's anything else I can help you out with, I've been through it all MANY times
. Timing cover, including opti(95 has the same opti 94 is different) timing set(again 95 is the same 94 different) and CPS reluctor, knock sensors, and damper hub.
There was only one LT1 block made, three timing covers and all of it can be made to interchange fairly easily.
Even a 93 would be little problem.
Once you find one let us know and we can be more detailed.
