A.I.R. delete/removal???
Old Feb 6, 2008 | 12:09 AM
throttlejunkie1's Avatar
Default A.I.R. delete/removal???
Hey fellas, I just installed a set of MAC mid lenth headers on the LT1 this weekend (PITA)... I got to looking at the overall appearance under the hood. I see that I have a lot of potential cleaning up what I already have and making it look really nice. One thing that I'm wondering is, can I remove the A.I.R. check valves and tubing and weld up/cap off the header inserts? This would make a better appearance especially on the passenger side. I had a custom 2 1/2 in y-pipe made and threw the cat in the dumpster! I'm under the impression that there is really no need for that a i r system now.?.?. Any ideas? Thanks
late 95 Trans am LT1...
Old Feb 6, 2008 | 12:16 AM
infinitebird's Avatar
You are correct, the only function of the air system is to heat up the exhaust for the cat.
Old Feb 6, 2008 | 02:11 AM
Formula350's Avatar
Isn't the AIR pump for the EGR and nothing to do with the cat except indirectly?
Old Feb 6, 2008 | 02:45 AM
no. AIR has nothing to do with EGR. Its only purpose is to heat up the exhaust like I said.
Old Feb 6, 2008 | 04:40 AM
t-rocks firehawk's Avatar
will it set off an ses like it does the newer ones?
Old Feb 6, 2008 | 04:53 AM
myk's Avatar
myk
Yup. Good thing that it's a relatively easy system to diagnose and fix...
Old Feb 6, 2008 | 04:59 AM
chavez885's Avatar
Yes, removing the AIR or EGR usually sets a code off. It can be removed with a tune.
Old Feb 6, 2008 | 10:53 AM
Default air
Thanks for the advice. I could easily cap off the insert on the headers, leave the a i r tubing open (because it just blows air) and leave the pump installed for now. To me, that shouldn't set a code due to the fact that the system is still functioning but just not the way it was ment to... right???
Old Feb 6, 2008 | 11:04 AM
sweet-94z28's Avatar
I know on the OBD 1 cars, you just make sure the fuse is good and you pull the pigtail out of the air pump. Then there is no SES light. I didn't have an AIR pump for a while so this is what I did.
Old Feb 6, 2008 | 12:50 PM
blk97z28's Avatar
ya cap the headers and remove the A.I.R. system.
Old Feb 6, 2008 | 01:55 PM
chavez885's Avatar
right
Old Feb 6, 2008 | 03:13 PM
Formula350's Avatar
Well my AIR plumbed into the back of the intake next to the EGR *shrug*
Old Feb 6, 2008 | 04:28 PM
Rocky70304's Avatar
You can get block off plates for the back of the intake for the egr and air system.
Old Feb 6, 2008 | 06:40 PM
StolenRedCamaro's Avatar
unhook the air tubing from the headers, and connect it to your intake - free supercharger
Old Feb 6, 2008 | 08:24 PM
Default seriously....
I don't know about all that... I'm kinda gulable but if it were plausable, I think everybody would be doing it. Besides, the a i r pump only operates at idle/low idle I think.
Old Feb 6, 2008 | 10:14 PM
yup, it's only on at idle
Old Feb 6, 2008 | 10:41 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I just pulled that bitch off of mine. That thing was amazingly difficult to get to.
Will that work with the 93 ECM?
Old Feb 6, 2008 | 11:09 PM
Default done
Well, heres what I ended up with. I welded a two way bolt. Then I self screwed the a i r check valve into one of the ends and welded it too (after I removed it from that long *** piping). Screwed it into the header, cut the hose to length, and plugged it back in. I probly need to post a picture for a better visual.
Over all outcome, the a i r system (technically not used) but still in tact and appears much neater within the engine bay, instead of wrapping all the way down the valve cover and back. Plus, I have so much more access to get in there and torque check my header bolts on occasion.
Let me know if you guys would like a picture of how it ended up.
Old Feb 6, 2008 | 11:36 PM
Sounds like it worked. That should work on the 93 ECM. All it does is check the circuit.
Old Feb 6, 2008 | 11:46 PM
OWN3D BY MY PROF!
I'm guessing by the way it works I can't cut those wires without throwing the code then?
