2 bolt 4 bolt
Old Feb 6, 2008 | 11:56 AM
Powder96SS's Avatar
Default 2 bolt 4 bolt
call me an idiot or a noob but how do you tell the difference and did any camaros come with the 4 bolt main lt1s or just the corvette
Old Feb 6, 2008 | 12:06 PM
LT1MAN's Avatar
some of the later f-bodies got the leftover 4 bolts from the corvettes when they started putting ls1's in them. there may be a number in the vin that represents if it is a 2 or 4 bolt, but other than that just take the oil pan off and look. if its a 2 bolt it will have 2 bolts on the main caps, if its a 4 bolt it will have 4, if its an ls1 it will have 6.
Old Feb 6, 2008 | 01:28 PM
sweet-94z28's Avatar
My 94 is numbers matching and it has a 4 bolt. My block is a Corvette casting number and the mains do have 4 bolts.
Old Feb 6, 2008 | 01:43 PM
gatorhead's Avatar
Yeah they really used what they had when they had them. No way to be sure other than to look or get the casting numbers.
Old Feb 6, 2008 | 05:36 PM
96capricemgr's Avatar
There was only one LT block casting, covered the LT1 2 and 4 bolt as well as the LT4.
By the time 4 bolts becomes genuinely a good idea you should be looking at aftermarket caps anyway and might as well go splayed so if anything a factory 4-bolt should be viewed as a NEGATIVE.
Old Feb 6, 2008 | 05:41 PM
fergymoto's Avatar
Factory 4 bolt blocks can be expensive. I sold one on eBay a while back and it went for $420. Like Grandpa Caprice said, you can convert to splayed caps for that kind of money.
