Be cool or CAS radiator ??
I've decided to get a radiator and am debating between Be Cool and Charged Air Systems aluminum radiator.
The Griffen radiator is not an option as I've got clearance issues and need a stock width radiator (about 1/4 inch clearance between the fan motor and the 12 rib belt
I know the Be Cool radiator is an exact fit and am pretty sure the CAS one is as well.
Is the Be Cool worth the extra $200+ ? or will the CAS one do the same job?
Marc
Marc
Re: Be cool or CAS radiator ??
I'm running a CAS radiator with my LS1 iron block setup, that with a 16" spal fan keeps me around 180 degrees in the HOT summer heat...
Where can you get a CAS radiator? I've never heard of one but I might be in the market for a new radiator pretty soon, and also have to clear a 12 rib ATI setup.
