Edelbrock head and valvetrain ?s
Old Feb 9, 2008 | 08:59 PM
bigbadblack93z's Avatar
Default Edelbrock head and valvetrain ?s
I have a set of LT1 edelbrock heads and I belive that the previous owner did not buy longer pushrods as required. +.1 so thats a 7.3? Also the springs say they are good to .600 lift but I seriously doubt that they offer decent performance at that lift. I will be at nearly .575 w/ a 1.6 rocker and want to turn around 6500 rpm.
Is anyone running these heads and if so how hard are you pushing them? The car barely runs now as it was a 1/2 finished project when I got it but they really aren't any better than stock from what I've seen, just benefical to me since I don't have to pull them and do a valve job on 100k miles stockers.
Old Feb 9, 2008 | 11:47 PM
Blackbirdws6's Avatar
I am up around that lift with the 1.6rr's and haven't had any valve float or other issues. Knock on wood.
Old Feb 10, 2008 | 04:42 AM
looks like we have a very similar set up, how's it run? I'm still bolting stuff on and waiting on a tune.
which rockers are you running and did you go w/ guide plates or just S/A rockers? longer pushrods?
thanks in advance for the info.
Old Feb 10, 2008 | 09:26 AM
96capricemgr's Avatar
Lift is NOT the only important thing. Lobes have different rates of lift and something like the XFI lobes will push a spring into float well below it's rated lift.
Old Feb 10, 2008 | 09:58 AM
It runs pretty strong (380rwhp, 370rwtq) at a pretty low ~6k rpm. I don't even bother spinning it much past that since the power starts to trail off a bit. However, it does run better ET's spinning it to 6500. I am not even full bolt-ons so there may be a few hp left on the table. It's fine but I plan to have these heads ported at some point in the future.
I have the crane gold RR's. I think they are the SA but I forget, it's been a while. I do have longer pushrods as recommended in the edelbrock install documents.
-Brian
Old Feb 10, 2008 | 10:16 AM
VendettaV6's Avatar
did the edelbrock heads help alot with power? I wanted to get a set of heads sometime and those seem to be the cheapest.... unless you are looking at ported stockers that various people are selling....
Old Feb 10, 2008 | 05:37 PM
they don't flow much better than stockers from what I've read and seen. I bought them with plans to have them ported but I had to get the car done so it never happened.
-Brian
Old Feb 10, 2008 | 05:44 PM
Be careful with "car runs good" reviews. A HUGE number of guys out there with slow cars but don't realize it. Look for measured results.
I don't think you will find anybody knowledgable saying much good about the Edelbrocks.
Old Feb 10, 2008 | 05:52 PM
96lt1m6's Avatar
the only reason their stuff sells is due to the name.i have not seen 1 componet for an L98,Lt1 or Ls1 that is competitive with others that are out there. hate to bash a company that has been serving the car community for decades but the advanced technology for our cars have yet to come from them, sad to say.
Old Feb 10, 2008 | 06:47 PM
yea its a shame these didnt perform better out of the box but I didn't want to port the stock heads but the car does indeed run strong...not as strong as a well-ported heads car but damn well none-the-less. I would like to see some ported edelbrocks vs stock ported heads. Just curious.
-brian
