58mm throttle body on stock engine
Old Feb 11, 2008 | 10:31 PM
mean_greenZ's Avatar
Default 58mm throttle body on stock engine
will i notice a difference? i have longtubes and k&n cai as well
Old Feb 11, 2008 | 10:33 PM
gatorhead's Avatar
some throttle response but powerwise no. The stock one is rated for up to 450 hp.
Old Feb 12, 2008 | 08:20 AM
StealthFormula's Avatar
It's overkill no need to add a 58mm or even a 52mm on a stock engine. The stock manifold and heads/cam only allow so much air to flow through the engine. You may even lose a little bottom end with a 58mm.
Old Feb 12, 2008 | 08:25 AM
Slowmaro95Z28's Avatar
Stock is best for you. A 52 is the biggest you want to go on a stock cube motor even with a huge cam and heads. 58 is mainly for strokers or forced induction.
Old Feb 12, 2008 | 02:08 PM
VendettaV6's Avatar
what they said ^^
Old Feb 12, 2008 | 11:49 PM
throttlejunkie1's Avatar
I put a 58mm on mine and lost a little bit of bottom end. Should have done my research...It was donated though so it didn't really hurt my feelings
Old Feb 13, 2008 | 06:05 AM
qwk93ta's Avatar
My 93 makes about 380 RWHP now and I still have the stock TB.
Old Feb 13, 2008 | 08:21 AM
Gabbiani's Avatar
I've made 510rwhp through the stocker and hope to make more soon.
Old Feb 13, 2008 | 11:38 AM
95hitam6's Avatar
my car came with it, so i don't know the difference, wish the dude bought headers instead, thats my next mod.
Old Feb 13, 2008 | 12:12 PM
hi officer's Avatar
my car made around 550 with the stock one and forced induction. how much will a 58 benefit me?
Old Feb 13, 2008 | 01:02 PM
96z28's Avatar
58mm way to big, 52mm good
Old Feb 13, 2008 | 01:29 PM
gatorhead's Avatar
Hard to say all we know is you have a car and it made around 550 and forced induced. Generally a larger TB helps a great deal with an FI motor and IMHO without knowing exactly what you have I say you can't lose by going bigger since FI is all about cramming as much air as you can get into one then thats the job of a larger TB.
Old Feb 14, 2008 | 05:42 PM
Whitez406's Avatar
I have a 58 on my car and the only thing i have is maf and a k&n cai rite now. I got it for free so i used it. I noticed a differance is throttle response but nothing else. Didnt seem to loose or gain anything its exactly the same just snappier.
Old Feb 14, 2008 | 07:55 PM
James Montigny's Avatar
Shouldn't really hurt any, but you don't really need it.
My car happened to have one when I bought it (mounted to an unported manifold with an adapter).
I opened the bores to match when I did my LE-ported H/C/I install.
Remember that stock manifold ports are only 52mm, putting a bigger intake on there without porting
is probably not the smartest idea.
Old Feb 14, 2008 | 10:12 PM
Ed Wright's Avatar
9-Second Club
My 383" didn't make more power with a 58mm versus a 52mm until it started to make more than 500 rwhp. Last time I tested it the 52mm made 526 rwhp, the 58mm made 532. All gains were above 6500. That is, of course, NA. I would be suprised if a boosted engine gained more than that.
Of course, old as I am, I have not sen everything yet.
Old Feb 14, 2008 | 10:19 PM
speed_demon24's Avatar
Have you done any testing with MAF's to see at what point the stock one becomes a restriction?
Old Feb 14, 2008 | 10:32 PM
SS RRR's Avatar
Village Troll
When he tuned my car years ago he yelled at me for having a ported maf. We put stock halves and my ported ones on and there was no difference. Dynoed 370rwhp (numbers were grossly off since it was only running 110mph after that dyno and when I actually made 370rwhp I was running 115mph) That was probably extremely usless for you, but hey.. I'm bored.
As far as the OP is concerend... no it won't make a difference. I don't see how a TB is entered into the volumetric efficiency equation.
Old Feb 14, 2008 | 10:38 PM
Yeah it was, 110mph is garbage.
Hopefully you can break 115mph with your new setup
Old Feb 15, 2008 | 10:08 AM
Ed Wright's Avatar
9-Second Club
I don't yell at people like that, I try to explain that is a useless deal. I saw only 3 or 4 rwhp from an 85mm MAF over a stock MAF at 420 rwhp, and then only at very high RPM. I didn't gain anything in speed density mode until 460/475 rwhp. Then about 1/2 MPH and 3 or 4 hundredths of a sec quicker. Then every time the weather changes I had to tweak temp correction tables. 95% of guys doing that stuff are wasting time and
money.
Old Feb 15, 2008 | 10:51 AM
96capricemgr's Avatar
I am not going to get into whether an 58mm is worthwhile. I am however going to try and see if I can make some sense of information.
I think MOST claims of big power gains from TB swaps are from people who can not tell the difference between throttle response and power. First time my wife drove the Caprice after the 58mm swap and other mods including a 600rpm stall rise she nearly launched backwards across the road backing out of the driveway. Even with a converter that should have left it a little looser the big bores drastically alter lowend throttle response.
Anyone losing power I have to wonder what they did wrong, like maybe not opening up the bores right and leaving some intrusion into the bore which would be a BIG hinderance to flow.
