Header bolt sizes
Old Feb 12, 2008 | 03:07 PM
StealthFormula's Avatar
Default Header bolt sizes
Anybody know what size header bolts we use on our cars? I want to get some bolts with an allen head so I can tighten them down better and get rid of my leak caused by my loose bolts.
Old Feb 12, 2008 | 03:43 PM
Gabbiani's Avatar
3/8 16 threads 1" long
Old Feb 12, 2008 | 08:36 PM
^great thanks!
the ones Im looking at are 3/8 16 threads but says .750 in. underhead length is that ok or does the underhead length need to be 1in., I the .750 is an inch counting the head?
Old Feb 12, 2008 | 09:57 PM
Gabbiani's Avatar
.75 will work - I used them for years NA. When I switched to my turbo setup I had several pull the threads out from the weight, heat, flexing, etc.
I would recommend going 1" because the hole is deep enough for them - More threads will hold better and be more likely to not strip.
Old Feb 13, 2008 | 01:27 AM
mtperformance's Avatar
Why not get some Stage8 locker bolts?
Old Feb 13, 2008 | 08:15 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Personally, I would not use 3/4" bolts. I would get 1" bolts. If you're looking for locking bolts, I think there are better alternatives than Stage 8. Percy's is now making what used to be Breslin Split Locks.
Old Feb 13, 2008 | 08:19 AM
Gabbiani's Avatar
The bolts are good, but I have never been able to use the locking clips. Every set of headers I tried they wouldn't fit. The split lock ones do well if you want to spend the coin for them.
I just ordered some plain ARP 1" bolts to put back in my setup.
Old Feb 13, 2008 | 09:21 AM
Paul Bell's Avatar
That's MISTER MODERATOR
https://ls1tech.com/forums/showpost....45&postcount=6
Old Feb 13, 2008 | 09:56 AM
thanks for the link I was able to find some 1in allen heads at the spectre website and just ordered them.
