Windage tray
Old Feb 13, 2008 | 07:21 PM
Chevyguy358's Avatar
Default Windage tray
i just recieved my shortblock back from the builder recently and I was aboiut to put the windage tray on and realized that he didn't use the studs that allow for the mounting of the tray...what should I do. I would perfer not to remove the main bolts.
Old Feb 13, 2008 | 08:53 PM
fergymoto's Avatar
Get the right main bolts with the windage tray studs and change them or go buy an oil pan with a built in one.
Old Feb 13, 2008 | 09:31 PM
ulakovic22's Avatar
Removing main bolts and replacing them aren't that big a deal. Just use a torque wrench and put them back to 75lbs with the correct bolt/stud.
Old Feb 14, 2008 | 12:44 AM
bigdan1's Avatar
no choice ...... remove the bolts install & torque the studs to specs,
easy!
