Top end/nitrous questions
Old Feb 18, 2008 | 03:20 AM
Wicked94Z's Avatar
Default Top end/nitrous questions
Still not sure if I'm going to go with a 355 or a 383, hopefully this'll help me decide. My stock shortblock's days are numbered with the current setup
DD days are over for my car, going for bogarts and a 28" slick, but sticking with the 6 speed. Will be running stock PCM, so RPMs need to stay south of 7k.
Planning on spraying a 250+ shot regularly through the new engine (setup for dual stage progressive), will be upgrading to a converted single plane to solve the distribution issues.
Since its going to be mostly a track car, I plan on running a solid roller nitrous grind planned shifts at 7k. My question is if the 250+ shot and 383 will be restricted by a stock casting (LE3 or Ai 200)? I don't really want to step to an aftermarket casting so that's where the 355 comes in... Clearly splayed mains and head studs are in order, should I also look into block filling?
Opinions welcome on the whole setup as well, thanks!
Old Feb 20, 2008 | 08:28 PM
Wicked94Z's Avatar
this isn't uncharted territory....
Old Feb 22, 2008 | 10:09 PM
Wicked94Z's Avatar
i know there's people running both heads (LE, Ai), and there's a few people spraying 250+ shots on this board.... little help please
Old Feb 22, 2008 | 10:13 PM
daniel6718's Avatar
cubes should be dependant on the weight of the car mostly...and tranny id say bigger is better almost always though...more cam more power....smaller cubes smaller cam
