Whats Next...?
Old Feb 20, 2008 | 06:07 PM
LT1forever's Avatar
Default Whats Next...?
I'm new to the forum, but I've recently had some work done to my to my 95 z-28 T-56. I got my heads portednpolished, installed the best comp cam available for the LT1, and had a 52 mm TB installed as well. The mechanic estimated anywhere from 425-450 hp. What would you suggest I do next to make this car even faster? The car already has an SLP Loudmouth and a Fipk filter. Any suggestions?
Old Feb 20, 2008 | 06:13 PM
97badass's Avatar
well you sir do NOT have 425-450 rwhp...maybe at the crank...im sorry to burst your bubble about that, but the next thing you HAVE to do is get it tuned, then start on the suspension, power withouth suspension = wasted money & time n then you might want to get a tougher clutch if your running the oem clutch. and you want to get your intake ported n polished too but do this BEFORE you do the tune.
Old Feb 20, 2008 | 06:16 PM
LT1forever's Avatar
Like I said, it was simply an estimate. Who should I deal with for a good tune?
Old Feb 20, 2008 | 06:22 PM
CRAZZ28's Avatar
rear gears or better yet a whole rear end, lt headers, suspension
how much were the heads ported? flow numbers? and what specs are the cam?
