Cutout questions?
they have both electric and manual in stainless and mild steel
the easiest and cheepest way to install it is to cut the pipes and have it welded in. if you used clamps you would have to get two pieces of pipe that are slightly larger to connect the two ends, you would need four clamps and some sealant. Ya basically it would be cheaper and easier to just weld it in.
& yes, 75$ out the door fellow firehawk brother
