Clylinder Heads???
Clylinder Heads???
I just picked up my engine from the machine shop today and I discovered that they installed the heads on the oppiset side from where I took them off. My question is does anyone know if they will work like this? GM only has one part # for the heads so I think they will work but I just want to make sure. Also does anyone know the part # for the washers that go on the rear of the heads and exacly what their called? Thanks.
Thanks. Yes they pluged the holes in the rear so I will have to move them to the front. Do you know witch side the coolent temp sensor goes on? Currently it is on the right passenger side if your standing behind the engine.
correct. it goes on the left side. those plugs might suck to pull out. think i tried to pull the ones on the intake and gave up. scared i might pull the threads out with it. might just be easier to flip your heads if they are on a stand.
