coolant bubbles
Old Feb 23, 2008 | 10:09 PM
fordeater's Avatar
Default coolant bubbles
Ive been worrying about the head gasket lately after the heads/cam job. Today I ran it for a while with the radiator cap off, and seen lots of little bubbles coming up through the radiator. The car runs fine, coolant does not overflow and does not go down, sparkplug was dry, oil is not milky anymore, no white smoke out of the exhaust. is the system just working all the bubbles out of it or could it be a problem, you guys think im just scaring myself??
Old Feb 23, 2008 | 10:22 PM
SS RRR's Avatar
Village Troll
probably air residuals from the swap. you may have to drive it for a few days before all air is has escaped.
Old Feb 23, 2008 | 10:39 PM
fordeater's Avatar
yea, ive been freaking myself out alot with it, the oil was turning milky first from all the assembly lube and thread sealer from head bolts, now this but i havent really been able to drive it because of the weather here.
Old Feb 24, 2008 | 02:03 AM
fordeater's Avatar
anyone else have any ideas?
Old Feb 24, 2008 | 04:40 AM
3pnt4maro's Avatar
give it some time...make sure you bleed what you can off..
Old Feb 24, 2008 | 07:02 PM
fordeater's Avatar
you guys think it could be a head gasket
Old Feb 25, 2008 | 09:55 PM
fordeater's Avatar
anyone??
Old Feb 26, 2008 | 12:32 AM
iceman15's Avatar
did you bleed the coolany system yet?
Old Feb 26, 2008 | 01:34 AM
MadMike 97 Z28's Avatar
well my car is currently torn apart because i had the same problem im pretty sure my problem is a headgasket it smoked out the exhaust and smelled like coolant. I also noticed bubbles with the cap off after much bleeding and i didn't have any milkshaking of the oil either it was so bad that after a few days of sitting it would be hard to start cause enough coolant had made its way into the combustion chamber and was attempting to hydrolock. cross your fingers bud i would hate to see another LT1 with a bad head gasket.
Old Feb 26, 2008 | 08:10 AM
fordeater's Avatar
the only thing is my car is not smoking, and the bubbles are not very consistent.
