Power differences?
Old Feb 25, 2008 | 01:06 PM
marcusicp's Avatar
Default Power differences?
What made stock LT1s from different cars have different power ratings? Is it simple things like intake and exhaust set ups? Or was it something to do with the PCM tune? Or was there different engine specs? Thanks!
Old Feb 25, 2008 | 01:11 PM
ROUDA's Avatar
2 cats in stead of 1 10 horsepower
Old Feb 25, 2008 | 01:14 PM
96capricemgr's Avatar
A little bit of all the above. Changes to the engines themselves were not in the shortblock though they wwere heads and cam.
Old Feb 25, 2008 | 01:21 PM
marcusicp's Avatar
So it's not worth spending the time looking for a higher hp stock engine if I was going to rebuild it anyway right?
Old Feb 25, 2008 | 01:52 PM
No not atall.
The Vette motors can actually be argued against. If 4-bolt mains are needed then you want aftermarket caps so you might as well go splayed better to start with a 2-bolt block.
The LT4s were the highest rated BUT that was in the heads and cam and they are NOT that great a place to start.
There was only one block casting.
Old Feb 25, 2008 | 01:59 PM
marcusicp's Avatar
OK, so at what point do I need a 4-bolt? I was planing on going splayed 4-bold anyway but when is it really needed?
Old Feb 25, 2008 | 02:02 PM
LT1MAN's Avatar
ive heard up to 650 is safe on a 2 bolt, i wouldn't go much past 5xx personally.
Old Feb 25, 2008 | 02:10 PM
marcusicp's Avatar
Oh wow! If its that high I should be safe for a long time! I will still do it anyway just for the heck of it. I was planing to dump a ton into my short block and build the top end and do power adders as cash allows.
