Are LTx's worth it?
I need some of the crack your smoking.....GIVE EXAMPLES!!
Just because the "magazine" you picked up has an LT1 BODIED car in it...for sure does not mean it has an LT1 in the engine compartment!
There are MANY LT1 "BODIED" cars in the 8's and even 7's.
And it "SHOULD" run 8's and ACTUALLY running 8's are 2 VERY different things.
EDIT I take that back, there IS a twin turbo purple T/A from Thunder than runs in the 8's...so thats THREE I have heard of.
David
And why do Impala guys chunk them in favor of aluminum castings?
David
The iron head is the better design (its actually a reverse cooled version of the vortec head)... but its iron!
http://www.malcams.com/legacy/misc/headflow.htm
So why are people not trying to swap Impalls LT1 heads on there cars? Is it the weight difference?
David
Purchasing a head like you described is almost not worth it, might as well port the stockers.
There is a difference in compression ratios you can use, do some searching on this topic please. Im not an expert on it, but ive read this stuff many times more than once. Purchasing a head like you described is almost not worth it, might as well port the stockers.
The 9% figure is what Injuneer calculated. (225 CFM cs 206 CFM) I didnt come up with that myself... i just trusted the guy with 30k posts in LT1 tech on cz28
because we all drive stock eliminator cars here
There is a difference in compression ratios you can use, do some searching on this topic please. Im not an expert on it, but ive read this stuff many times more than once.I dont expect it to ever happen for that reason. I was merely illustrating that our engines have more potential we have not tapped yet. Everyone loves the LS1 because they have better heads... and we know for a fact that better LT1 heads COULD exist if someone made them.
that is all i am saying.
in terms of flow:
stock iron > stock aluminum
ported iron > ported aluminum
Since its only a 9% difference at most, its pretty obvious that
ported aluminum > stock iron
