I just got a nitrous express kit...
Old Feb 27, 2008 | 12:30 AM
emj2006's Avatar
Default I just got a nitrous express kit...
Just as the title states I just got a nitrous express kit.. now what all do I need to do prior to installing it?? I got the NGK plugs ready of course, I guess I gap them to .035?? Any other things I gotta do, I dont want to blow up the motor!! lol. And yes I've tried searching but to no avail..
Old Feb 27, 2008 | 01:43 AM
BLACK 97 SS's Avatar
i would upgrade my fuel pump
Old Feb 27, 2008 | 01:55 AM
Formula350's Avatar
Well since you don't have a sig listing your mods (if any), it's hard for us to give any advice. You also didn't tell us how big you went. Another helpful tidbit is what you plan on doing in the near future, so we can tell you things to get now that'll save another upgrade later.
I'm no NOS guy but I'd say change your cap and rotor as well as get a bigger fuel pump (may as well change the fuel filter too), some injectors probably wouldn't hurt if it's a higher mileage motor (Red Top FORD 30#s come on the 4.0 V6s). Retard box wouldn't be too bad of an investment either.
Bare minimum? I'd say the fuel pump.
Old Feb 27, 2008 | 09:36 AM
LTwonZ's Avatar
We need to know a few things about the car before we can really help you. How big of shot do you plan to spray? Is the car an auto or stick? What other mods do you have? Have you checked on getting a FPSS and or window switch?
Old Feb 27, 2008 | 09:57 AM
StealthFormula's Avatar
Is it a wet shot or dry? If dry you will definetly need bigger injectors and a fuel pump.
Old Feb 27, 2008 | 10:36 AM
emj2006's Avatar
Alright, it is a 125 wet kit. I got bolt ons(long tube headers, y pipe, ram air, ported heads, mild cam(not sure which one, but it came with the car, tb)
Old Feb 27, 2008 | 10:43 AM
LT1MAN's Avatar
ported heads, stock cam??? did you blow a head gasket or something?
Old Feb 27, 2008 | 11:05 AM
emj2006's Avatar
So.... any recommendations??
Old Feb 27, 2008 | 11:27 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
These are the parts I would want if it was my car:
Base Kit (you have this covered)
Window Switch (safety)
FPSS (safety)
Purge (performance and safety)
Heater (performance)
Pressure Gauge (performance and safety)
NHRA valve and blow down tube (safety)
Spark Plugs, TR6 or equivilant
Timing Retard (multiple options)
Here is a link to the description of each accessory
http://www.nitroustech.com/forums/showthread.php?t=2
Please let me know if you have any questions,
Ray
Old Feb 27, 2008 | 11:41 AM
emj2006's Avatar
Awesomeness.... how about NGK TR55 plugs?? Would those be good??
Old Feb 27, 2008 | 11:44 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
No that is the stock heat range...you want to be one step colder for nitrous use.
Old Feb 27, 2008 | 01:27 PM
Formula350's Avatar
If gauges = performance, no wonder Ricers get the biggest Monster Tach that goes to 10K Rs I'd say that's just categorized as Safety.
Old Feb 27, 2008 | 02:05 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Correct pressure will increase performance.
Too low or too high can affect the safety of the kit.
Old Feb 27, 2008 | 03:19 PM
chavez885's Avatar
Good info ray. Whats funny is on your post on nitroustech, cockpit is blocked
Just thought i'd point that out.
Old Feb 27, 2008 | 04:07 PM
Formula350's Avatar
True, but a gauge will only depict the pressure, it won't adjust it for you and thus no performance gain/loss by having it. It's merely a safety device. By your logic, my gas gauge is a performance piece since it tells me how much gas I have left
Old Feb 27, 2008 | 04:27 PM
chavez885's Avatar
Old Feb 27, 2008 | 04:47 PM
SlowGreenTA's Avatar
Thats when you use the bottle heater to adjust your pressure, and using the gauge you can stay in the optimum pressure range for your kit, getting the most hp out of the system. Its not that the gauge itself is a performance adder, its the information it gives and what you do with it.
Old Feb 27, 2008 | 08:47 PM
Formula350's Avatar
Exactly, that's why you can't call a gauge a performance add-on. That's my whole point
Old Feb 28, 2008 | 02:52 PM
3pnt4maro's Avatar
does it really freakin matter guys..we all know what was meant by the comment..lets get on with the thread if the poster has any more questions
Old Feb 28, 2008 | 04:16 PM
CHELOZ28's Avatar
To the OP, thanks for posting.
This is on my list for my future NX KIT.........Remote electronic bottle opener,NX accessory power switches,nozzles,solenoids ,WOT switch w/bracket,blow down tube,automatic bottle heater ,pressure gauge, purge kit,10 lb bottle,Dual gauge pillar,NGK's...
Anything else that would be needed for safety?
Thanks guys
