LS6 springs on an LT1?
Old Feb 28, 2008 | 09:35 AM
Ironxcross's Avatar
Default LS6 springs on an LT1?
Would it work?
Old Feb 28, 2008 | 10:17 AM
speed_demon24's Avatar
With what application? They should work with the 918 hardware, but the ls6's have a MUCH lighter valvetrain than LT1's and they definatly wont be enough for most aftermarket cams.
Old Feb 28, 2008 | 10:20 AM
Ironxcross's Avatar
I was planning on going with 1.6 rockers and later on maybe a cam.
Old Feb 28, 2008 | 10:28 AM
I wouldn't use them even with a cam with extreemly lazy lobes. They only have 90 lbs of seat pressure IIRC.
Old Feb 28, 2008 | 10:34 AM
slick1851's Avatar
Just get aftermarket springs, or a pair of lightly used ones
Old Feb 28, 2008 | 11:56 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
They have 120lbs at 1.800 installed height. I probably wouldn't use them with 1.6 rockers. I think you saw my other thread. The reason I said they'd be a good alternative is because I plano on using LS1 valves in my LT1 heads. They're considerably lighter and a smaller stem.
