Those with Canton LT1 valve covers, inside please...
Old Feb 29, 2008 | 11:02 AM
Formula383's Avatar
Default Those with Canton LT1 valve covers, inside please...
Trying to figure out a few things:
(1) Does the stock PCV valve and grommet fit in the hole on the passenger side cover?
(2) What breather are you using? If the threads on the oil cap are the same as stock then I can just get a Metco. If not, what are you guys using?
Kyle
Old Feb 29, 2008 | 03:57 PM
mean_greenz28's Avatar
I am pretty sure that the stock PCV valce and grommet fit in the passenger side. I'm in the process of building a new engine and i'm 99% sure that we just went to the auto parts store and bought a stock PCV grommet for it. I think the threads for the oil cap are different than the stock one bc it comes with its own cap. As of now i'm not running a breather there so i can't help you out too much more.
Old Feb 29, 2008 | 04:01 PM
Pro_built7's Avatar
uhh guys, the pcv valve is on the driver side of the intake manifold not the valve cover.
Old Feb 29, 2008 | 04:07 PM
My bad. I was thinking that since he said that was where the PCV was that he was right. whats on the passenger valve cover then?
Formula383's Avatar
So what is in the grommet on the passenger side valve cover then?
Old Feb 29, 2008 | 04:21 PM
Formula383's Avatar
Ok, so it's not the PCV valve but it is a crank case ventilation opening that goes to the throttle body.
Old Feb 29, 2008 | 04:53 PM
transamws6_97's Avatar
yup it goes from the back of the passenger side valve cover to behind the blades on the passenger side of the tb
Old Feb 29, 2008 | 05:49 PM
Lt1junkie's Avatar
And NO it doesn't not fit at all the hole is much bigger on the cantons.. i went to autozone and got a bigger gromet and it worked... hope that helped ya out
Old Feb 29, 2008 | 10:39 PM
ulakovic22's Avatar
No the stock grommet doesn't fit the hole. Go to O'Reilly's and in the help sectin there are grommets. Looks for 42323 I believe, maybe 43232, it will be a tight fit but works great and the ID is the right size for a Fram, Purolator or Duestch filter. After I switched I haven't gotten any oil in my intake, I think it's because they are taller and I'm running a filter now.
Old Mar 3, 2008 | 11:15 AM
Formula383's Avatar
Thanks guys. I'm gonna try and round up some of this stuff.
