Time for LT Headers and a Y-Pipe. Need Advice
up from underneath. No problems. As far as lifting the engine for the
emissions stuff, I dont think so. My tranny is out, so I'm having an easier go
at the header installation.
Except for now. Sheesh! The #2 bolt for cylinder #1 - I'm having to run to the
hardware store because the socket-head bolt wont work because the #1 pipe
makes a quick bend to the rear, not allowing an allen wrench to go one.
Also, I cant use the Kooks-supplied 12-point bolt because a closed-end wrench
cant get around the bolt head (too close to the pipe) and of course, you can't
use an open-end on a 12-point. So, it's off to the hardware store AGAIN to find
a standard stainless hex-head 3/8-16 3/4" bolt. It's gonna look a bit goofy with
one hex head bolt and the rest socket-head.
Do the Kooks folks even TRY to use their supplied hardware with their headers?
NOT. Also, I question their "quality control" . . . I had to grind the center portion
of the driver's side header flange, because when I put a straight-edge on the
flange, it had a bit of a "hump" in the center, meaning the outer ends of the
flange would NOT have mated flat against the gasket/head.
Sounds like you're having some issues I didn't experience. That kind of sucks considering the price of the headers. Mine were perfect. If not, I would have probably been a little upset.
bits. But after reading this post, I decided to take one of the 5/16x1/4 "screwdriver"
bits (the 5/16" end fits into the socket-head bolt) and the 1/4" end, of course, fits
into a magnetic screwdriver or 1/4 mini-ratchet/etc.
This allowed me to use the 3/4" long stainless socket-head bolt (versus having to
use a hex-head bolt) . . . and to fit the modified screwdriver bit into the bolt and
use a open-end wrench to tighten it up. It's a *much* cleaner look now that I've
got *all* six socket-head bolts.
socket-head bolt, using a screwdriver bit and mini-ratchet to tighten down:
http://picasaweb.google.com/calder.cay/Z28
How much will i gain if i go with race headers as opposed to emissions style headers?
http://www.ws6project.com/user_stor/...roducts_id=740
are they REALLY that expensive? wowow
If you're looking for a locking header bolt, I would suggest the stainless steel Percy's Split Lock, which used to be the Breslin Split Lock. They'll probably cost more than the Stage 8's, but I think they're a far superior design. If Stage 8's were the only locking header bolt on the market, I would have gone with regular stainless ARP's instead. Lots of people think the Stage 8's are pain in the butt to install. Also, I would use a 1" bolt.
