reman opti spark?
Old Mar 9, 2008 | 06:47 PM
RallyBoy's Avatar
Question reman opti spark?
what make the reman opti spark units from oreilly's, autozone, etc. so bad? the only part i can see that may be faultly is the optical sensor. why not just use your factory optical sensor in place of the reman?
Old Mar 9, 2008 | 06:50 PM
AR15 guy's Avatar
Half the reman. ones probably do have factory optical sensors. The problem with them is the fact that they use cheap parts to repair broken opti sparks.
If the optical sensor is ok in a core they get they will just replace whatever is wrong. So your new "re manufactured" opti spark may have parts with over 200k miles or something.
Which makes them not last.
Old Mar 9, 2008 | 07:08 PM
RallyBoy's Avatar
what else is there to go wrong? im not doubting you but, the only thing i can see going bad is the bearing. my car is down right now and i need to get it running by wednesday so i thought a reman would do. i was going to replace just the cap and rotor but the bearing in my opti must be going bad because it is hard to turn and there was debris underneath the metal plates.
Old Mar 9, 2008 | 07:32 PM
halucinator's Avatar
Just buy the one off of ebay, its brand new. Mine is still working great after 6 months of use.
Old Mar 9, 2008 | 07:39 PM
97badass's Avatar
worst advice yet!
Old Mar 9, 2008 | 07:58 PM
Originally Posted by 97badass
worst advice yet!
How is that? Are you using one?
Old Mar 9, 2008 | 08:37 PM
AR15 guy's Avatar
Order a GM unit from jegs or summit. Extremely fast shipping and a good price.
I don't trust much stuff on ebay. To many shady sellers.
Old Mar 9, 2008 | 09:21 PM
gatorhead's Avatar
I got mine from all-ignition off ebay and it has correct pn and cap.....I have seen pics of different **** from other places and even heard bad about them, but after digging I found that it was blemished delcos, absolutely nothing wrong with them save for a ding in the casting which hsa nothing to do with how it works or functions heres the pics:
Old Mar 9, 2008 | 09:28 PM
infinitebird's Avatar
maybe they changed up the ones they are using then. Some they sold had a clearly non-GM cap (it was black instead of yellow, etc).
Old Mar 9, 2008 | 09:40 PM
gatorhead's Avatar
Yeah I seen those too and the date in the pic is when I got is so less than a week ago
Old Mar 9, 2008 | 11:58 PM
RallyBoy's Avatar
gatorhead, have you installed this opti yet? if so, what is your opinion about the unit?
Old Mar 10, 2008 | 12:03 AM
gatorhead's Avatar
I actually have not installed it I did speak with at least a dozen of the folks who had bought the same item and all were extremely happy. A few of them are my comrades on another site and they have been put to and through the test.
As I stated earlier I CANNOT tell a difference between my original Delco and this one at all.
Old Mar 10, 2008 | 03:31 AM
I replaced mine with a brand new black cap opti. The seller told me it was a genuine GM opti, just an off brand cap. Its worked since I've installed it in august of 07 and its holding up great.
Old Mar 10, 2008 | 08:51 AM
Pony_Killer's Avatar
almost all that stuff on ebay is crap!! they say its a true " GM opti" but its A1 which is what autozone oreillys reman crap..trust me buy a OE GM opti not as cheap but in the long run it will be cheaper then buying crap every year...trust me
