stumped
Old Mar 10, 2008 | 01:03 PM
Formula350's Avatar
I said it before, I'll say it again, since it happens during warm temps try new O2s.
Old May 15, 2008 | 07:18 AM
1980LT1's Avatar
Ok so did you ever fix this problem? I am having the same issue with my LT1. I have a 1980 Datsun 280ZX with an LT1/T56 swap. I just installed a new opti with new connector and ignition control module. It runs great under any type of throttle. The only code I am getting is a lean right bank. The LT fuel trim is +25 but the o2 is switching normal. I know I have to do some part throttle and idle tuning yet. Could this be the cause of my problem? I have never seen an O2 sensor cause a stall but I guess anything is possible. What would cause the O2 to cause a stall? Is the PCM shutting down something for some reason...aka too lean?
Thanks!
Guy
Old May 15, 2008 | 01:18 PM
Revelation Z28's Avatar
i was getting code 16 for low-resolution pulse from the optispark. the optical sensor clouded over and there was a nice amount of rust dust in there.
Old May 15, 2008 | 01:28 PM
djjab57's Avatar
Did that fix it if not i had the same problem hard to start when hot it turned out my ignition switch was bad the one on top of the colum
Old May 15, 2008 | 01:32 PM
yea its been fixed for a few months now.
im looking around for a set of coils and brackets for the LTCC so itll never happen again.
Old May 15, 2008 | 01:33 PM
djjab57's Avatar
Lol a lilttle late on the update there glad its fixed
Old May 16, 2008 | 12:06 AM
1980LT1's Avatar
Well mine seems to be the ECM itself. I checked codes again tonight and when it died on me it threw a 41,42, and 51. I checked my wires (for DTC 41 and 42) to the ICM as per Alldata's diagnostic flow chart and it lead me to faulty PCM(which is what code 51 is basically).
Hopefully I can get a new ECM tomorrow from the local salvage yard and load up my tune and be on my way!
