Need to flush all the fluids.
Old Mar 12, 2008 | 01:15 PM
Comegetusome's Avatar
Default Need to flush all the fluids.
Im going to changing my opti,water pump, coil here very soon. What all needs to be flushed fluid wise? I figure the water pump and the radiator fluid. How do I flush the water pump and the radiator? I think the radiator flush is on the passenger side on the bottom corner of the radiator. Not sure about the water pump. Pictures would help if possible. Thanks Alot!
Ps. its a 96 T/A
Old Mar 12, 2008 | 11:21 PM
anyone?
Old Mar 12, 2008 | 11:26 PM
ROUDA's Avatar
Just take the lid off your rad open the petcock. Im not sure are you going to be removeing the rad or fans for the opti install
Old Mar 13, 2008 | 01:39 AM
I already have the fans off. I dont think ill need to remove the radiator. Petcock??
Old Mar 13, 2008 | 02:00 AM
ROUDA's Avatar
petcock is the name of the drain under the rad. You just turn it until it opens up. You could just disconect the lower rad hose. If I were you since your replacing the water pump take that off first then install the opti that way its done.
Old Mar 13, 2008 | 11:20 AM
Thats what I was planning on doing. What all needs to be drained though, just the radiator??
Old Mar 13, 2008 | 12:35 PM
ROUDA's Avatar
Yea I think thats it.
Old Mar 13, 2008 | 02:05 PM
Thats what I thought, just wanted to double check.
