Help me get traction!!
Old Mar 15, 2008 | 06:42 PM
wwmost's Avatar
what angle do you usually put it at for the track? how many degrees should i adjust it?
Old Mar 15, 2008 | 11:55 PM
96LT1355Z28's Avatar
If you do a search in ther rear ends section there is some discussion about it. I believe -2 is pretty standard for stret and strip driving. I'm still setting mine up (installing) and I'm not that far yet!
Old Mar 16, 2008 | 12:01 AM
CamaroRacing12's Avatar
ET Street radials FTMW!!! and maybe some QA1's?
Old Mar 17, 2008 | 10:45 AM
bluebeast's Avatar
get the BMR track pack suspension and ET street radials......hooking a car can be the easiest thing about this stuff it you let it be..... i had no suspension with a blower back in the day wondering why i am running like **** at 7.5 s and 7.9s and the woke up and said ok i will break down and buy the suspension...... then i started running 6.5s and 6.6s..... get the suspension man!
Old Mar 17, 2008 | 10:49 AM
bluebeast's Avatar
and nittos are hardly any better than a good rated street tire that gets 40,000 miles...... ET street radials , or atleast some BFGs...... and a 15 inch weld wheel with a 26X10.5 will help.... i run a 28 inch 12 inchs wide to hook my car and it still dont work on a WOT leave.....going ET drags this time with track bite on them bitches!
Old Mar 17, 2008 | 11:12 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by wwmost
ok well i went to the track last night and i was really mad at my times. i couldnt hook for **** especially when boost kicked in. my 60's were a low of 2.3! i would go 13.7 and trap at 110 lol. i tried slippin the clutch easing into it all of that. ran 5 times all the same deal. i have nitto drag radials in the rear. lower control arms, some lowering springs im not sure maybe slp they were on the car when i bought them and a rear pan hard bar. i just bought the car and its ready for a big overhaul suspension wise. i have about 1500 to spend and its really a track/nice weekend day car. what do you recomend? im going to keep the stock rear with the 4.10's until that blows
im sorry but im still a newb at f bodys but can you tell me the basics in getting it to hook? i cant get sub frame connecters because of my sts piping running along the subframs. also what wheel offset/spacing do i need?
We have several options available if you would like to give me a call here at the office and I can go over them with you .
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old Mar 17, 2008 | 12:38 PM
wwmost's Avatar
the thing is i have some of the pieces in the track pack and i cant use the subframes with the sts kit. can you take some money off then?
