Help me get traction!!
Old Mar 12, 2008 | 01:56 PM
wwmost's Avatar
Default Help me get traction!!
ok well i went to the track last night and i was really mad at my times. i couldnt hook for **** especially when boost kicked in. my 60's were a low of 2.3! i would go 13.7 and trap at 110 lol. i tried slippin the clutch easing into it all of that. ran 5 times all the same deal. i have nitto drag radials in the rear. lower control arms, some lowering springs im not sure maybe slp they were on the car when i bought them and a rear pan hard bar. i just bought the car and its ready for a big overhaul suspension wise. i have about 1500 to spend and its really a track/nice weekend day car. what do you recomend? im going to keep the stock rear with the 4.10's until that blows
im sorry but im still a newb at f bodys but can you tell me the basics in getting it to hook? i cant get sub frame connecters because of my sts piping running along the subframs. also what wheel offset/spacing do i need?
Old Mar 12, 2008 | 01:57 PM
wwmost's Avatar
i also have kyb shocks/struts but dont know the settings on them. are they any good?
Old Mar 12, 2008 | 02:36 PM
socal's Avatar
It sounds like you need to launch harder as far as your short times. What are you droping the clutch at? If your slipping it, you are burning it and you may need a better clutch to hold the power, are you heating the tires up well enough. Play with the air press in them. I would start with that and leave the suspention unless you'r going to do the qa1's all around or some thing like that. Just make up your mind if is going to be a street car or track only car, with the qa1's you can have both, are the kyb's the adjustable one's if so start playing with them soft in the rear hard up front.
Old Mar 12, 2008 | 02:46 PM
chavez885's Avatar
4.10's with a blower? Do you have LCA reloc brackets? How much power u putting down? A 110 mph trap speed sounds pretty shitty for a forged 383 turbo car.
Old Mar 12, 2008 | 03:17 PM
SlowGreenTA's Avatar
do you have an adjustable Torque arm already? Ill assume you do, so you should check for correct pinion angle to help you out a bit, some people run as low as like -3* but i would only use that for the track. If you DONT have an adjustable TA (like me, shh dont tell) you should get one soon, they can help a ton.
Ive also found that for our track, the prep degrades really fast past about 60', so easing into the power doesnt help much, you just spin later. The earlier I was spraying the better the car hooked up , so may be similar for you depending on track prep. I also havent heard many good things about nitto DRs. Try heating them up more or less, and play with the air pressure to try and get them to stick.
Old Mar 12, 2008 | 03:58 PM
The LT1 That Could's Avatar
Get rid of the Nittos! You're not gonna hook a 6 spd car, much less a Stroked, Boosted 6 spd car, on Nittos. Dump some money into a Tire/Wheel Combo...15" with either a M/T Drag Radials, or a DOT approved Slick of some kind (ET Street, QTP DOT).
Old Mar 12, 2008 | 10:20 PM
screming_z28_95's Avatar
i would get a bmr adjustable torque arm and either et streets or some bfg's
Old Mar 13, 2008 | 07:39 AM
wwmost's Avatar
i dont have relocation brackets for the lower control arms. what do they help? also im going to order a torque arm this week what do you recomend? and i guess im going to get rid of the nittos but i still have the stock 10 bolt so im hoping it will hang in there when i really get traction. and yes i have 4.10s, i bought the car like that and it sucks! whenever the rear blows im going to switch to a taller gear because i shift every second and have to go into 5th at the end of the 1/4. i have a spec stage 3 clutch, new so that isnt slipping. my car isnt slammed but it is lowered, does that effect things much on f bodys as far as traction?
Old Mar 13, 2008 | 07:51 AM
PewterScreaminMach's Avatar
This is almost exactly what I was going to say (he said it better, though).
Old Mar 13, 2008 | 08:34 AM
blackz6sp's Avatar
X3 even if ya didn't want to go to a 15" tire, put some MT drag radials on it will be a huge improvement over the nittos.
Old Mar 13, 2008 | 09:27 AM
SpeedDensityZ's Avatar
The ET Street Drag Radials are the shiz. I have run both and the MT hooks better cold than the Nittos heated up.
Old Mar 13, 2008 | 10:32 AM
97badass's Avatar
driver mod dumdumdum
Old Mar 13, 2008 | 10:41 AM
wwmost's Avatar
yea i admit it im not the best driver out there but i garentee it wasnt all me lol. what size 15 wheels do i need, offset and backspacing? i had mt's on my mustang and they are GOD haha. but yea i still have the stock 10 bolt how long do you think that will last, or there is really no telling? i might as well run it till it blows.
Old Mar 13, 2008 | 01:56 PM
thebufenator's Avatar
dude....you should really change those 4.10's out for something like 3.23's.....
the turbo will like you if you do that
Old Mar 13, 2008 | 02:57 PM
infinitebird's Avatar
there is no telling but...
10 bolt + 4.10s + 6spd + turbo
not going to last long once you start hooking
Old Mar 13, 2008 | 03:31 PM
wwmost's Avatar
i HATE THESE 4.10S!. whenever i get a new rear they are gone. i shift every second. i just want to get 1 run off before it breaks lol. come on baby hang in there
Old Mar 13, 2008 | 08:05 PM
I8ASaleen's Avatar
I hear 3.42's are a good gear for an FI car, but I would say like everybody else get some ET streets with some 15" Welds or something like that I don't remember the backspacing maybe someone else can help. Oh and my stock 10-bolt is going with a blazing stock engine so don't count on it for too long.
Old Mar 14, 2008 | 12:26 AM
96LT1355Z28's Avatar
Talk to Eric at Midwest Chassis. He has good stuff at very reasonable prices. http://www.midwestchassis.com/ I would reccomend the LCA relocation brakets, adj. TA, and better tires. Eventually (when the rear breaks!) loose the 4.10's for somthing higher they are probably killing your turbo. Good Luck!
Old Mar 14, 2008 | 07:46 AM
wwmost's Avatar
why do you recomend an adjustable TA?
Old Mar 14, 2008 | 12:46 PM
It will help you set pinion angle for better traction when you launch, especially since your car is lowered. It also will not flex as much as the stock one which will prevent wheel hop.
