missing from idle
Old Mar 12, 2008 | 02:30 PM
starbucks's Avatar
Default missing from idle
hey guys i have a 95 t/a, well the car started missing out of know where from an idle all the way up to red line. it is a faint miss and the car lacks power and there are no codes. any ideas? ignition control modual maybe? checked all the plugs and plug wires but came back with nothing. i dont think this has anything to do with it but i was trying to track down a ticking noise so I re adjusted the valves to make sure it wasnt valve trian related. i did the enigin running meathed were i loosin till it starts ticking the go until it stops and then a 1/4 turn did it three time didnt make any difrence well it ended up being an exhaust leak. any help would be apreciated thanks
Old Mar 12, 2008 | 06:19 PM
starbucks's Avatar
to the top
Old Mar 12, 2008 | 07:52 PM
97badass's Avatar
did you fix the exhaust leak?
Old Mar 12, 2008 | 08:26 PM
starbucks's Avatar
yes i did. and i it seems to be an intermitant problem that isnt heat related.
