Compression Test Help Please!
Old Mar 13, 2008 | 06:28 PM
nemanracing's Avatar
Default Compression Test Help Please!
So I went to do a compression test on my 96 Camaro Z28 as I had my spark plugs out. I bought the only tester it seems that all of the auto parts stores carry Actron or something. It has an adapter that screws into the spark plug socket, then a rubber hose with a one way valve in it that goes up to a quick connect to the guage. All seems fine but i do not have enough room to screw the hose into the adapter. I tried to find something like a quick connect to go in between the adapter and the hose. I have a male part that fits the adapter but i can not find a female part to fit the hose??? Any ideas?
Old Mar 13, 2008 | 07:09 PM
buffman's Avatar
if you have the same gauge as I do, that extension adapter is for heads that have the plugs recessed pretty far into the head. You can screw the hose right into the head..
Old Mar 13, 2008 | 07:21 PM
I went down to my local industrial hose and fitting place and they cut the hose and fit in a quick connect for me for 10 bucks... Now to see if it works...
