uh oh another missing out thread
Old Mar 16, 2008 | 08:49 PM
xxcoolrollinxx's Avatar
Default uh oh another missing out thread
well ive had a problem for a while .. everytime i get on it and it misses out when im at like 6000prm .. really high rpm miss .. im an A4 .. i may be wrong but it always does it and acts like it doesnt wanna shift .. but after missing out a bit it does shift .. could this be opti symptons ? .. i changed it not to long ago .. but i used a shitty opti .. my car isnt throwing any codes .. could my transmission problems be a factor ? .. my tranny is slipping extremely bad .. well give me some of your thoughs
Old Mar 17, 2008 | 12:22 PM
bumpp
Old Mar 17, 2008 | 12:41 PM
wwmost's Avatar
what do you mean missing out?
Old Mar 17, 2008 | 12:45 PM
355z28's Avatar
sure your just not bouncing off the rev limiter??
Old Mar 17, 2008 | 01:45 PM
seems like i am
but have never had that issue
it does bounce tho
Old Mar 17, 2008 | 02:19 PM
355z28's Avatar
thats what it sounds like to me, i know a ton of fbody cars that bounce off the rev limiter 2-3 times before going into 3rd, mine does it occasionally, my buddies forumula does it every time.
Old Mar 17, 2008 | 02:28 PM
seawalkersee's Avatar
Sounds to me like you have a fuel problem. But then you would probably not be able to get to 6k if there was a lack of delivery. Does it rev all the way to 6k as it normally would?
Chris
Old Mar 17, 2008 | 06:38 PM
ill try and get a video and show you guys
Old Mar 17, 2008 | 07:34 PM
Badazz 97 TA's Avatar
you answered your own question, the transmission is slipping.....
Old Mar 17, 2008 | 08:35 PM
infinitebird's Avatar
lol "missing out". sounds like your car is lonely or something
Old Mar 18, 2008 | 06:35 AM
so thats whats causing the bouncing off the rev limiter
Old Mar 18, 2008 | 11:58 AM
yes that will cause it to bounce off the limiter
Old Mar 18, 2008 | 12:30 PM
ineedanls1's Avatar
my buddy's 95 z was doing that then he had the tranny rebuilt with a shift kit no longer an issue...
Old Mar 18, 2008 | 01:24 PM
woo woo
i hope so guys
tranny rebuilt in a month so ill bump the thread when i do
Old Mar 18, 2008 | 02:23 PM
Formula96's Avatar
mine does it to, tranny is fresh, hell i don't know. Mine has gotten worse over the years, now it won't even shift 1-2 at WOT unless i let out.
need to get lt1 edit, maybe that will fix it...
Old Mar 18, 2008 | 02:30 PM
355z28's Avatar
Highly doubt the transmissions slipping up there, my buddies formula has a fresh tranny in it, and i just build mine with tci clutches, tci wide kevlar race band, beast basket, hardened input/out put shafts, dual caged sprag gears and a transgo shift kit, and a billet corvette servo, not to mention the valve bodies been gone through
when it started doing it i thought somthing was wrong with it so i swapped to another one and it did the same thing, so im back to the one i originally went through and put new pins in. Pretty sure its something in the computer as far as a shift window is, im going to hook mine up and see if i cant change it around and fix it.
Old Mar 18, 2008 | 04:28 PM
hmm
ruh roh
