Fuel all over engine bay and under car!
Old Mar 18, 2008 | 09:13 AM
Formula350's Avatar
Originally Posted by B-Rad420
What about the air pump, the egr system, the stock air silencer/donkey dong on the intake, the stock air box with all its baffles, this is just a few I thought of even though most are not super important like something such as fuel. But just because a factory designed it dosent always mean something to me. Time and research is what matters to me. The car has been out way longer that the amount of time it took to design all of it. Lots of time for changes/improvments and finding out you dont need certain things anymore. Brad
Air Pump and EGR: Emissions, needed for most states. Air silencers, not needed but it was to keep outside noise down, as with the stock air box.
You need the clips, stop beating a dead horse
Old Mar 18, 2008 | 01:43 PM
Steve in Seattle's Avatar
Post
I read that all the clips do is hold the injectors in when you pull the rails off so fuel does not drip everywhere. I found this info by searching so I tried it out myself with no harm a few years back.
I also havent driven this car in several years... Today I cranked my car and fuel shot out of the fuel rails around the injectors
Originally Posted by b-rad
Actually my injectors do move up and down. I still dont think that they can be popped out though without the fuel rail loosening or the injectors wearing down from moving around to where they can slide down further.
Originally Posted by Steve in Seattle
No matter what injectors you run, you need clips to keep the injectors in the rail... the LT1's beveled bungs allow injectors to wiggle down and out of the rail.
And yes, this leads to HUGE amounts of fuel because it's a large leak from the pressurized rails...
How can you be so stubborn and clueless? I just hope no one takes you as an authority and follows suit. Ahhh... this should help:
I also found my number 5 and 7 plug wires crossed. That solved my backfiring problem hopefully. Now just to do the valve lash one more time while its running to get it in check. Cant wait. Gonna see how this b body short block runs with alum heads and 1.6 rockers with hotcam springs
Like any other stock engine with 1.6 roller rockers. Hotcam springs are crap.
Old Mar 18, 2008 | 02:46 PM
B-Rad420's Avatar
I had holes in my o rings....thats why I leaked fuel. The injectors didnt move at all much less pop out. Drove the car today and guess what. Injectors didnt even move...even though they can be pushed up and down a decent amount. I thought hotcam springs would be pretty nice springs for my b body cam with 1.6's but oh well. I dont care what anyone views me as. I just come here for help and try my best to help others.
Old Mar 18, 2008 | 02:53 PM
B-Rad420's Avatar
Oh and I didnt actaully cross the plug wires. They were already in my wire looms and I just plugged them up. The car hasent run in 3 years because someone built a motor for it and it spun a bearing the first day and he set up the plug wires.
