Smog legal Cam more aggresive then cc305/Hot Cam?
Old 03-18-2008, 06:22 AM
MonmouthCtyLS7's Avatar
Default Smog legal Cam more aggresive then cc305/Hot Cam?
Looking to keep it legal(Jersey). Lookin for something a little more agressive then those mentioned above...any advice ?
Old 03-18-2008, 07:17 AM
registered user
ScreaminRedZ's Avatar
I'm sure there are plenty that will pass, but the manufacturer will probably not guarantee that it will because it's probably not officially for highway use.
Old 03-18-2008, 08:54 AM
slingshot928's Avatar
the cc305 is a pretty good cam, if you put that in with some 1.6 rr's, you should be pretty good...the cc306 or something in the comp cams xfi line would be great too.
Old 03-19-2008, 07:06 PM
95ZRagtop6M's Avatar
My car passes NJ inspection with LE emissions cam. The duration is in the mid 220's with about .570+/- lift with 1.6RR.
Old 03-19-2008, 07:22 PM
LS1TECH Sponsor
NightTrain66's Avatar
about the best "catalog cam" is gonna be the CC 503 cam (224/230 .533/.54 112 LSA). It just needs to have very little overlap so this requires low durationa dn a wide LSA to keep overlap down.
Lloyd
Quick Reply: Smog legal Cam more aggresive then cc305/Hot Cam?
