PCV Question
Old Mar 20, 2008 | 04:25 PM
94Z28man's Avatar
Default PCV Question
I recently installed taller proform valve covers and installed a valve cover breather on the driver's side cover. I still have the pcv system. Will this cause a problem and should I have some type of filter for the passenger side valve cover so oil doesn't get sucked into the throttle body since I removed the valve cover baffles.
Old Mar 20, 2008 | 04:42 PM
Formula350's Avatar
I have a breather there, no problems. What problems are you thinking there'd be?
Old Mar 20, 2008 | 05:01 PM
94Z28man's Avatar
Thanks for the fast reply and I've heard that having a breather causes a vacum leak. What did you put on your passenger side valve cover or did you just put the vaccum line back.
Old Mar 20, 2008 | 07:00 PM
Formula350's Avatar
The breather is IN the valve cover. I capped off the TB.
