LT4 composite valve covers not fitting...Need help fast.
I have a rather high lift cam with Comp pro-mag 1.6R roller rockers.
Anyone ever run into this problem. What do I trim? Gotta wrap this up tonight.
Don't know what else it could be, I was under the impression the LT4 covers had more rocker clearance.
All Corvettes used plastic covers as you are showing. Those are not LT4 covers.
The real LT4 covers do not have the bumps inside the covers, in order to clear the factory rockers arms.
Well then good to know.
When I cut these "drip tabs" off, do I need to prep the cut surface or leave it alone. Seems oil might soak into the cut areas. I know super glue would soak into the cut area and seal it up.
Any thoughts?
