Where to tap power for nitrous...
Old Mar 22, 2008 | 09:46 PM
azboostin's Avatar
Default Where to tap power for nitrous...
wondering best/easiest place you guys tap from to power a nitrous system....
Old Mar 23, 2008 | 11:05 AM
ZL1SS's Avatar
To do it you need to run a relay directly off the battery since the solenoids pull alot of current. I would suggest running the entire system including the arming switch off the battery as an independant system and make sure you use fuses as well. I have seen people run the controls off the radio fuse but I just find that as the easy way out.
Old Mar 23, 2008 | 11:09 AM
96lt1m6's Avatar
back of the alternator is the best..
Old Mar 23, 2008 | 11:15 AM
azboostin's Avatar
cool what about power for arming the relay
Old Mar 23, 2008 | 11:27 AM
99FormulaM6's Avatar
best bet is finding a switched 12v power source. Running off the battery is an OK idea, but you run the risk of draining the battery if you forget to turn off the switch.
