Gasket Set Questions
I was thinking of getting either Mr Gasket MLS head gaskets or SCE copper gaskets. I'm running stock LE ported heads that have been shaved down and my block has been decked with 11:1 compression pistons
Also what other gaskets am I going to need? I'm not going to pull the crank out or the cam so just the intake, tb, and head gaskets right?
Thanks in advance guys
I am curious what cause your rings to not seat. Was it synthetic oil?
My engine builder never decided with a thickness just said run stock replacement, but with the higher compression ratio I want to run a little better gasket this time around and have heard that the mr gasket MLS are good
I just hope everything works out better this time around
