Which throttle body?
Old Mar 24, 2008 | 12:30 AM
01cherryreds10's Avatar
Default Which throttle body?
I've been wanderin' around the forum, haven't found any recent threads that would help, so I made this one.
On a 97' WS6, Flowmaster cat-back, Pacesetter longtubes, Hypertech, and K&N intake, which TB would you all suggest?
I found both a BBK 51mm and 58mm, as well as Edelbrock's 51mm and 58mm TB's.
Which do you guys think is a better choice?
Thanks.
-Eric
Old Mar 24, 2008 | 12:33 AM
porksoda's Avatar
neither...stay stock.
Old Mar 24, 2008 | 12:38 AM
Really? I'm kinda looking for some mods nothing too dramatic, maybe will pick up some time at the track. It's a daily, so nothing too big.
Old Mar 24, 2008 | 12:42 AM
tspence45's Avatar
A bigger TB isn't really going to get you any gains. The stock one is supposed to flow well enough for up to 450hp, I believe. If you want to pick up a few tenths, swap out that Flowmaster catback for something a little better flowing. Like an SLP Loudmouth setup, or maybe get some gears. A bigger TB is a waste of a few hundred bucks.
Old Mar 24, 2008 | 12:57 AM
Alright thanks much guys.
Looking for some ways to get it to hook a little better too if anyone has any vauge suggestions.
Old Mar 24, 2008 | 01:09 AM
97LT1's Avatar
Do some lower controll arms. They will stiff up the back some.
Old Mar 24, 2008 | 01:38 AM
Red on Red WS6's Avatar
Is your car A4 or M6?
Old Mar 24, 2008 | 05:29 AM
gatorhead's Avatar
Yeah at this point your tb is perfectly fine. A larger TB is only going to help wih throttle response but will not make it any faster. Take your money for that and put it into a quality suspension setup. That way when you do decide to make more power you can get it to the ground. Spinning ain't winning!
Old Mar 24, 2008 | 10:20 AM
StealthFormula's Avatar
Im also going to tell you to spend the money elsewhere at this time in your modding. I would highly highly recommend that you get some Lower Control Arms which should make a noticible difference in traction and maybe a Torque Arm and some M/T DR's as well. Suspension was one of the best things I did with my car and seems to be often overlooked.
