Average HP gains...
Old Mar 24, 2008 | 11:31 AM
Elliott's94Z's Avatar
Default Average HP gains...
So is there really any HP gains going with a 52mm throttle body? Any dyno #'s out there from a stock 48 to a 52?
Old Mar 24, 2008 | 12:01 PM
Tom's_03SVT's Avatar
Just port and remove the screen in your stock unit. I saw 6hp, but it was a cold day...
Old Mar 24, 2008 | 12:08 PM
I've never heard of there being a screen in a throttle body..are you talking about the mass flow air?
Old Mar 24, 2008 | 06:42 PM
GIZMO's Avatar
FYI. The GM Performance Parts 502 ci/502 HP Ram Jet crate motor uses a twin 48 mm throttle body.
Old Mar 24, 2008 | 07:39 PM
I8ASaleen's Avatar
Yes, but it could benefit from a larger one
And no you will not have any gains (if you are stock) with just switching throttle bodies.
Old Mar 25, 2008 | 08:23 AM
MonmouthCtyLS7's Avatar
stock is fine, only time you need to upgrade is for fi or higher hp applications.
Old Mar 25, 2008 | 12:14 PM
GIZMO's Avatar
So, you are saying that you saw a true dyno gain swapping the throttle body on a GMPP 502/502? Same AFR? Please share your experience with us.
Thanks,
Daren
Old Mar 25, 2008 | 12:50 PM
Looks as if a 52 over a 48 gets you little to none. Guess it depends on what mods you have done to the motor. So I'm guessing that since I have full bolt ons it wouldn't hurt to use the 52. I'm guessing it will end up adding a extra 100hp..lol
Old Mar 25, 2008 | 01:22 PM
m6ttop's Avatar
I have a 52.I lost some torque but gained responsiveness if that makes any sense
Old Mar 25, 2008 | 02:23 PM
imnotplutonium's Avatar
when I changed mine i got little to no gains. but I am sure it helps responsiveness. since it matches the manifold.
