Window washer bottle thing...
Old Mar 27, 2008 | 07:59 PM
BsGreenZ's Avatar
Default Window washer bottle thing...
Ok so that container holding the window washer fluid behind the bumper, how can i get that out.. Do i have to take the bumper off or can i come in through the back and take the Y bracket out and bring it out, it looks like i have enough room but will removing that brace be a pain in the *** to get it back in...
Old Mar 27, 2008 | 08:13 PM
Hark_Z's Avatar
The bracket looks like a pain, yes. I took my wiper fluid reservoir when I removed my front bumper support. This in your TA or camaro? If it's mostly a track car or if you really don't care (like me) I'd take out the bumper support anyways.
Old Mar 27, 2008 | 08:49 PM
BsGreenZ's Avatar
It's in the dumdumdumdum and no its still a street car.. I told the fiance about taking the bumper support out and got an ear full lol..
Old Mar 27, 2008 | 09:24 PM
Hark_Z's Avatar
You don't her these things man c'mon.. In all seriousness my girl would kill me if she knew how unsafe my car was.
Old Mar 27, 2008 | 09:32 PM
BsGreenZ's Avatar
LOL yeah but she kinda helps with the car so it's not the easiest to get it past her...
Dragframe's Avatar
HAHA. My girl wont even get in my car after the turbo...
Old Mar 27, 2008 | 09:40 PM
BsGreenZ's Avatar
LOL my girl has never been in my car, not until the forged 383 with the bottle is done...
Old Mar 27, 2008 | 09:42 PM
Formula383's Avatar
I put mine back in last week with the entire front end together, but this was on a Formula. It slid right up between the air dam and front bumper cover. I just had to unhook the hood latch cable b/c it was in the way. Taking it out should be about the same. There should be 4 push pins. The bottom 2 are a biyatch to get out...
Old Mar 27, 2008 | 09:45 PM
BsGreenZ's Avatar
Do you think i can take that Y brace out and slide it out the back...
Old Mar 27, 2008 | 09:52 PM
Formula383's Avatar
You shouldn't need to remove the y brace. I know it looks like it needs to come out but it doesn't. Just remove the 4 push pins, the weather pack connector and fluid line and it will drop straight out.
Old Mar 27, 2008 | 09:58 PM
BsGreenZ's Avatar
Thanks man i'll try that tomorrow, now i get you to go work on the T/A lol, should be running here quick...
Old Mar 28, 2008 | 12:27 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
When I did mine my car didn't have the radiator, condensor, or front bumper on so I'm not 100% sure if this is helpful. They way I got those push pins out was I whacked them from behind and pushed them forward. They are most certainly a pain to remove though.
Old Mar 28, 2008 | 02:25 PM
Hark_Z's Avatar
All you need is a crow bar, then you can gently pull em from the top. Thats what I found to be the easiest after breaking a couple
Old Mar 28, 2008 | 03:04 PM
BsGreenZ's Avatar
I was going to pull it out today but i'm still stuck working on the Trans Am.. Trying to get this car done ASAP to see how the bottle hits ..
Old Mar 28, 2008 | 04:39 PM
BsGreenZ's Avatar
Ok so the more i looked at it the easier it looked.. I took out the 4 clips holding it in, than removed the black plastic piece the sits behind and under it by removing the 3 clips from the bottom and the 2 bolts on the sides and it slid right out the bottom no problem..
Old Mar 28, 2008 | 07:46 PM
Formula383's Avatar
Told ya...
Old Mar 29, 2008 | 12:35 PM
BsGreenZ's Avatar
Yeah thanks again man it really wasnt that hard...
