will 11in wheels fit without any modifications?
Old Mar 29, 2008 | 01:32 PM
97slowmaro's Avatar
Default will 11in wheels fit without any modifications?
i was looking at either getting C5 wheels or ZR1's but i wanted to know will 11in wide wheels fit without and modifications?..if not what is the widest wheel that will?
Old Mar 29, 2008 | 01:35 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The ZR1s will fit with some hammering of the inner wheel wells. Your car is also lowered so you'll probably have to roll the inner fenders.
Old Mar 29, 2008 | 02:16 PM
19mike84's Avatar
me and a friend put zr1s out back with 1/4 in spacers and it fit with no hammering. they also stick all the way out to the top of the quarter panel
Old Mar 30, 2008 | 12:06 AM
3DFORMULA's Avatar
Mine are the aftermarket ZR1 17x11 rear with 35mm back spacing. No hammering needed.
Old Mar 30, 2008 | 02:05 AM
NorthernZ's Avatar
I got the american racing torque thust II's in 11x17 out back and I rub in one spot that sticks out a bit in the inner wheel well when I'm putting the car sideways. I've got stock springs though, but let me tell you if the car's four seats are full of passengers I drive slow and easy and watch for bumps cause other wise the tires feel the wrath of the top of the inside wheel well.
But passengers slow you down, tell you your scaring them, and plain old take away from the mind set of total driving satisfaction...... Cheesy, yes. True, you be the judge.
Old Mar 30, 2008 | 02:23 AM
LT1BRN's Avatar
You dont really need to roll to finder but you will need the BFH mod.
Old Mar 30, 2008 | 11:59 AM
Jpack's Avatar
My oem zr1's fit without any mods, no BFH. They are the grandsport offset. 50mm. Only thing is on large bumps, the tire will make some contact. I curred that with some drag bags. I didn't feel like rolling the lip.
Old Mar 30, 2008 | 04:12 PM
OWN3D BY MY PROF!
The thing is he's lowered on the eibach pro kit. I think a lot of people are missing that. He's more than likely going to have to roll the fenders.
Old Apr 1, 2008 | 10:20 PM
r_trigg's Avatar
Default 19x11 fit with minimum work
I have a set of iforge Senekas in my 95 Camaro. They are supposed to be for a Z06 C5. Fronts are 18x9.5, Rears are 19x11. I use NO spacers and the wheel tucks under the car nicely in the rear. I had previousy shaped the inner fender well...near the LCA mount, for a 28x12.50 ET Streets. But other than that, not other mods to make them fit.
