starting problems and more
Old Mar 29, 2008 | 01:34 PM
maggotpez's Avatar
Default starting problems and more
Well I flew home for 2 weeks and when I got back my battery was corroded and the car wouldn't start. So I cleaned it up and it still wouldn't start. Then I replaced the battery b/c it was about that time anyway and now it will start about 70% of the time and somtimes I have to hold the key down for 20-30 secconds. Could it be the corrosion down in the wire? Secondly when I accelerate to 60+ and let off the gas the engine makes a looping sound and will jump from 1000 to 2000 rpms over and over about 6 or 7 times. I heard this could be caused by the EGR valve and I know mine is bad prob needs to be cleaned any ideas? Lastly I have a cylinder misfire code showing up I checked all the wires and they show to be all firing I heard this could be from a aftermarket cam. The car was modded when I bought it and I havn't had the time to check. Do you guys think that could be the cause?
Old Mar 29, 2008 | 07:15 PM
maggotpez's Avatar
no one?
