egr delete question!!
Old Apr 17, 2008 | 09:01 PM
  #81
Prototype007's Avatar
Originally Posted by camarostripes96
ok hey i found a guy that has a April special going on on pcm tuning , u pick 2 things from the list to do, Adjust for new Gear Ratio, Change Speed Limiter, Cut Fans On Earlier, Code Deletion, or Raise RPM !! Any 2 of those for $50.... so let me know if u are interested and pm me
My Hypertech can do all of that except code deletion.
Old Apr 17, 2008 | 10:18 PM
  #82
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
well if anyone wants to know some info or get in contact with him let me know
Old Feb 5, 2010 | 01:15 AM
  #83
offroadfury6's Avatar
i have a 2000 T/A WS6 with the LS1 motor (obviously). do I have an EGR? and does it need to be deleted?
Old Feb 24, 2010 | 09:38 PM
  #84
southpaw0314's Avatar
what guage steel do you recommend for making block off plates for air and egr?
Old Feb 24, 2010 | 10:44 PM
  #85
airfix's Avatar
Your cae will have it unless its been previously deleted. No you do not need to delete it, unless you want to.
Old Feb 24, 2010 | 10:45 PM
  #86
airfix's Avatar
It would be way easier to just buy block off plates and plugs than to buy metal and make them. There are tons of delete kits on ebay from $14-$25
Old Feb 24, 2010 | 11:35 PM
  #87
BlackBird87's Avatar
Camarostrips96 who is installing your headers. i dont mean to be a dick but i just read 4 pages on deleting egr. Header install is not going to be easy for you.
Old Feb 25, 2010 | 01:22 AM
  #88
MasterTomos's Avatar
I had my EGR/air **** deleted when I had my header gaskets redone...they said it actually made it easier for them to put it all back together...plus I dropped off about 10 lbs on uneeded weight off my car...
many places make LT1 block off plates, any decent shop should be able to fab some up for you too...
checkout TPIS's website, they sell a very clean looking set of block off plates, and like mentioned above, they aren't expensive.
you can see them here:
http://tpis.com/index.php?module=cat...%29+Dress+Trim
