Piston to valve clearance
Old Mar 31, 2008 | 08:22 PM
IronOutlaw's Avatar
Default Piston to valve clearance
i have a 94 lt1 that is on its last legs and will need to be rebuilt soon. but it has been run hot multiple times before i owned it and once when i owned it. the heads were milled down .080" and i was wondering if i will have any piston to valve clearence issues if i go with a bigger cam such as a cc503.
Old Mar 31, 2008 | 10:20 PM
10secondZ's Avatar
Whoa .080" is ALOT of milling on an LT1 head. How far did it cut into the valve seat on the intake? What cam do you have in there now and on what ratio rocker?
Old Mar 31, 2008 | 10:25 PM
96capricemgr's Avatar
Well I would worry that the heads are soft and will never really stay sealed.
I would also budget head gaskets into the cam swap and check PTV clearance, extra gaskets are cheaper than the consequences should it be a problem.
Old Apr 1, 2008 | 09:40 AM
IronOutlaw's Avatar
IM not too sure on the cam thats in the car now. the mechanic i hired to work on it for me has built a lot of lt1s, mainly caprice motors, and said he didnt think it had a stock cam by the way the rockers were adjusting. the car has always been a very strong running car for what is done to it. im not to sure on how far they cut into the valve seat though. i do know they had to pull the valves out to do it.
