what is this?
Old Apr 7, 2008 | 05:17 PM
jb442's Avatar
Since we've already diverged from the topic... One-per cylinder is the ideal setup since you can see how each is performing. You can get some good info. by reading the temps of each cylinder. Here's a short quote I found on the topic from the SAE:
The positive relationship between A/F ratio and exhaust gas temperature is well known. In the range of A/F ratios between 11:1 and 14.5:1, this relationship is almost linear. Most modern automotive engine management systems currently use exhaust gas temperature models based on engine speed, engine load, ignition timing, and A/F ratio (EGR is either constant or closed). Based on these relationships and empirically derived engine mapping, it is possible to calculate A/F ratio from measured exhaust gas temperature along with measured engine speed, engine load, and ignition timing.
Old Apr 7, 2008 | 07:23 PM
the_merv's Avatar
Veteran: Air Force
Originally Posted by 97badass
merv you forgot the regular valvecovers too
Good call..outside Bolts.. I missed that one..
Old Apr 7, 2008 | 09:08 PM
Formula350's Avatar
Guys it looks like it's on a dyno, c'mon now lol Of course it's going to be full of wires and odd plumbings.
