Where to put cut outs
Old Apr 7, 2008 | 11:51 AM
camarostripes96's Avatar
From: Academy,Tx (home of temple/academy Drag Strip)
Default Where to put cut outs
ok i have a 96 lt1 trans am,with pacesetter lt's and ory pipe, and i want to get electric cutouts , should i put 1 behind the y pipe or should i get 2 and put 1 each behind the header collectors so they are coming straight off the headers?
Old Apr 7, 2008 | 12:05 PM
30thanniversaryz's Avatar
Just put one right before where the pipe goes over the axle.
Old Apr 7, 2008 | 12:06 PM
Badazz 97 TA's Avatar
most people put it after the y-pipe. right after the headers will be stupid loud and annoying. but its all personal preference really. anywhere you want to put it you can. there isnt a right or wrong spot
Old Apr 7, 2008 | 12:11 PM
sdm1234's Avatar
many people use just one cutout after the y-pipe merge, mainly to save money haha. 2 cut-outs isn't really necessary, unless you want insane amounts of noise. also, i believe that the y-pipe merge helps with scavenging.
Old Apr 7, 2008 | 12:14 PM
ok well i didnt know if there was a certain length u had behind the header collector for enough back pressure
Old Apr 7, 2008 | 12:41 PM
sdm1234's Avatar
back pressure is not needed. you should be more concerned about exhaust velocity and scavenging.
Old Apr 7, 2008 | 01:20 PM
what do u mean by exhaust velocity?
Old Apr 7, 2008 | 04:42 PM
sdm1234's Avatar
the speed in which the exhaust gases comes out (determined by tubing diameter and length, and the temperature)
Old Apr 7, 2008 | 05:04 PM
m6ttop's Avatar
before the axle ^^^^^ is the most efficient IMO
Old Apr 7, 2008 | 05:44 PM
watkinss's Avatar
what if you had high flow cats in the y. anypoint in putting one just after the y or buy 2 and put them before the cats?
Old Apr 8, 2008 | 09:42 PM
anyone have pics of different kind
Old Apr 8, 2008 | 10:46 PM
screming_z28_95's Avatar
i have a QTP and it works awesome mine is after the Y but right before the axel there is a lil nitch in the floor pan and it fits perfect thats were mine is and every one else i kno around joliet
Old Apr 8, 2008 | 10:54 PM
where did u run ur wires to, like that go in the car and ur switch
Old Apr 14, 2008 | 04:28 PM
threw the passenger drain hole under the carpet and then into my center console i have teh switch in the center glove box and just wire every thing else up like it says
Old Apr 14, 2008 | 04:40 PM
19mike84's Avatar
i have a cut out, it dumps right before the rear axle. its loud and i like it
Old May 25, 2008 | 03:12 PM
ryle's Avatar
And... Where did you get the idea to mount the switch there.... oh wait... come to think of it, Who Installed your Cutout and switch for you....
Oh Yea, I Did!
