LT1 Top Stocker
Wait...Top Stock...is that IHRA?
In NHRA, you have to run factory lift. But you can put all the duration in it you want. The heads cannot be touched. Correct me on this if I'm wrong GIZMO. What gear are you running? I'm guessing around 5.13's with a ton of converter. That's where these cars make their power.
What's your class limit on weight? I'm pretty sure you're very close to it. Nice ride none-the-less.
The motor in this car is blueprinted to NHRA specs. Several racers have gotten together in IHRA Division 9 to run a heads-up Top Stock shootout at each race this year. We are running strictly by the NHRA Stock Eliminator rules.
The motor specs.
1. Bored .060 over with Ross factory replacement forged pistons (NHRA accepted).
2. Aftermarket forged rods (NHRA accepted. Note that the piston/rod/rings have a minimum NHRA weight. All eight assemblies in this motor meet this minimum).
3. Stock crank stroked .013. Rotating assembly is balanced, but not lightened.
4. Stock cam lift. Any duration is allowed, so this is where a lot of the HP comes from.
5. Deck height is approx. .064 including the gasket.
6. The heads are NHRA legal blueprinted stock castings. They have had a three angle valve job, stock diameter replacement valves, stock diameter and height replacement valve springs, and the combustion chambers measure approx. 52 cc's.
7. The rockers are stock and the lifters are modified stockers (almost solid now).
8. The intake and throttle body are untouched stock GM.
9. The headers are Kooks.
10. Fuel injection is by FAST with SVO 24lb injectors.
Transmission/Rear specs.
1. ATI TH-350 "Ultra" (has 2.52 first gear, aluminum drum, manual valve body, and lots of tricks).
2. ATI 5200 rpm 8" MRT converter.
3. Mark Williams aluminum driveshaft.
4. Strange 12-Bolt with light weight spool, gun drillied and star flanged axles, 5.14 gear set, and titanium 5/8" studs.
5. Turbo Action shifter.
Chassis specs.
1. Light weight brakes on all corners (Strange front and Wildwood rear).
2. QA1 single adjustable shocks.
3. QA1 front springs and stock rear.
4. Air bag in passenger rear spring.
5. BMR chrome moly torque arm and non adjustable lower control arms.
6. BMR sway bar.
7. Solid engine and transmission mounts. BMR transmission crossmember.
8. Mickey Thompson wheels and tires. 9" x 30" radials (biggest tire allowed in Top Stock).
9. Three gallon fuel cell.
10. Manual rack.
11. Modified stock K-member (to ease pan removal).
12. Manual aftermarket master cylinder.
Body/Interior specs.
1. Removed mirrors and other suttle changes that include stretched rear wheel openings (see what else you can spot).
2. Front impact stuff still behind the bumper.
3. Air bags, wipers, radio, sunvisors, interior light, and misc. removed.
4. Stock manual drivers seat (others removed per Top Stock rules).
5. 10 point chrome moly cage with dash bar.
6. Light weight carpet.
7. All panels in place.
8. Functional manual windows.
9. All stock glass.
10. Empty steel weight box (30lbs).
11. Through the floor frame connectors.
12. All stock body panels.
To run Top Stock by the NHRA rules the car has to weigh 2985 including the driver. The car weighed 3000 lbs on it's first outing. I am fixing to change a few things around to see if I can get my sixty foot times in line. I will be adding a second battery and changing the transmission soon, but the weight should stay about the same. The whole car will pass NHRA/IHRA inspection and engine tear down.
Take Care,
Daren
Good luck and awesome work.
Correct me if I'm wrong but a complete Woodro Josey built stocker motor can run you in the neighborhood of 30,000 bucks.
What class are you running....B/FIA?
I always said that if I hit the lottery, all I want is a stocker/super stocker. ****, if I hit the lottery, I might have both
.Good luck with it.
I do not have the flow sheets for the heads that are on the motor with me, because I am travelling this week. I can tell you that the flow at .500 - .600 is right around 205 - 210 CFM! They fall off after .600. My Camaro ran 6.61 @ 101 mph with a cam that measured 256/266 @ .050 (stock lift). It ran B/FIA at over 3200 lbs.
Jason is a super guy. I don't know him very well, but has always taken time out to talk Buicks with me. He and Greg have been nice enough to let us test with them a couple of times. I don't know Kevin, but I purchased some Buick parts from his brother Scott a few years back and he was really cool.
I am running the car in Top Stock and maybe I will run A/FIA at some points meets. If I run some NHRA stuff I will run B/SA.
Take Care,
Daren
Take Care,
Daren
So you've got to add a couple of hundred lbs to run B? Damn.
We had a guy from the track (No Problem Raceway) set a new record in stock last year. Hell, it might have been B/FIA. Anyway, they wanted to tear him down and he just loaded up and left...didn't tear down. Not a pretty sight. I forget what NHRA penalized him but they weren't very happy. He would drag the back bumper (in a Firebird, no less) and it ran 9.xx. I could get the times but he was obviously not up to specs inside the motor.
What division are you in? We're Div 4...The Good Guys.
Darren, did thise F.J. Smith motor mounts work out OK? I bought a set and the pan hit the K member. Hauled it across town and had it notched. Came back and tried to put the engine in again, and the pan hit the steering rack!
Would have made the engine like 5" lower in the car if it had cleared the rack. I would have been beating header tubes flat faster than I could buy them. Need to call to see if I can return them. I don't see how anybody could run them. Second set I bought from them and can't use. First time they sent a set for a V6 K member, for some reason. Should have returned them also. Freight up there is a little stiff. Thought it would be an easy way to put the bowtie block in the car. Ended up having to make a couple of pieces.
I have three sets of these mounts and had the exact same issues as you (2 sets LT1, 1 set LS1). If you look at the k-members that F. J. makes, he mounts the rack ahead of the factory position. The NHRA no longer allows aluminum mounts in Stock anyway. I now build my own mounts out of chrome moly.
To bad you arent local I wouldnt mind trading my 98+ tail lamps for a clean set of the 93-97s.
