LT1 Alternator/PS kit
And If Another B Body Owner Wanted Your Kit All You Would Need To Do Is Either Supply Them With 400/1000 In Spacers Or Make Tha Brackets A Tad Longer. I Think I Mean Yall Are Tha Designers
yes you are correct about it should only being a matter of different spacers
WITH the power rack in place and looped.Brake down
Entire Speed inc kit with only 1.925 Lbs with the belt and all the fasteners.
All the stock parts removed including fluid came to 20.74Lbs.
Not bad for a few hours work.
I would like to thank Larry and the guys at Speed Inc for the great part!
