2.5" or 3" true duals
And to have a shop do it you will probably be looking at close to $700 I'd say. And if they do it it won't be mandrel bent, unless your a lucky one who has a shop close by that has a mandrel bender. Why not look into the bassani true dual setup? Its about $800 and will bolt right in? Just a thought
And BTW I have 2.5" true duals, X pipe and dynomax bullets dumped at the axle, made by me with mandrel bends. Sounds absolutely badass, nothing around here comes to sounding like it but its getting changed out for a 1 off CME setup down the road
Alright I'm done rambling, and just so everryone knows I'm not trying to prove anyyone wrong are start a big argurement
$700-800 is a lot, if it's that much then forget out the back setup
Am I correct in saying not much custom work is needed for a dumped setup? (probably half the cost of out the back)
