Is it too close?
Old Apr 17, 2008 | 08:56 PM
Huff035's Avatar
Default Is it too close?
My drivers side header seems like its too close to the steering linkage. Does anyone else have this? Does it matter if its close, just as long as its not touching.
Old Apr 17, 2008 | 09:04 PM
Green3spd's Avatar
If its not touching, dont worry bout it... On my last car it did rub the header, I tapped a litte dent in the primary and it stopped...
Old Apr 17, 2008 | 09:36 PM
Badazz 97 TA's Avatar
turn the steering wheel all the way to the left and all the way to the right. see if it touches
Old Apr 17, 2008 | 09:40 PM
96silverram's Avatar
Put in new urethane engine mounts, problem solved. If the mounts are old (which most LT1's are by now) the engine will settle out of its original position.
Old Apr 17, 2008 | 10:15 PM
Huff035's Avatar
thanks. but if it doesnt touch. then it doesnt matter how close it is. right?
Old Apr 17, 2008 | 10:47 PM
Ironxcross's Avatar
the whole engine bay is clustered and close. get some poly mounts and be done with it.
